Main > Main Forum
My find of the day!
Pages: << < (6/6)
dek:
Location? If you are close, buy it and I will give you a working monitor with a cab.
Phatcat990:
--- Quote from: dek on February 28, 2005, 10:14:18 am ---Location? If you are close, buy it and I will give you a working monitor with a cab.
I am located in Barberton Ohio.
dek:
Damn, too bad I am in CA  :-[
southpaw13:
Sorry no multi-williams.  It is going to Mame and I am building a second control panel that I can swap out from time to time.  It will have 2 joys and 6 buttons for each.  I did this on my Robotron cab and it turned out great!
paigeoliver:
--- Quote from: Phatcat990 on February 28, 2005, 09:26:04 am ---I know where I can get a fully functional Atari Championship Srint cab for $100. I am just wondering if I will be able to use the monitor. The control panel, pcb, pedals I dont plan on using. I will buy the cab if I can use the monitor.
The monitor is medium res, which is the single most difficult monitor to use with mame (and EVERYTHING will be running the wrong resolution even if you do get it to work). You essentially couldn't pick a worse cabinet for Mame if you tried.
Pages: << < (6/6)
Go to full version
