Author Topic: mdf  (Read 2201 times)
sodapopinski
  • Last login:February 12, 2011, 11:13:41 am
  • if I only had normal friends
mdf
« on: February 11, 2005, 09:59:47 pm »
I'm ordering my wood tomorow and i'm a little tied up over 5/8" or 3/4" mdf. I dont think strenght will be an issue, but i'm concered a little about the t-mould. If i can find some locally, great, but chances are it will be 3/4". I really dont want to regret the size i chose, so, what would you recomend? also would going with the 3/4" greatly increase the weight?
Tailgunner
Re: mdf
« Reply #1 on: February 11, 2005, 11:03:00 pm »
I'd personally go 3/4", but it's just a personal preference.  A cab built of 3/4" will definately be a good bit heavier than one of 5/8".  How much is hard to say, there's quite a weight difference between my uprights and all of them were built using 3/4" thick material.
Wienerdog
  • Last login:December 08, 2020, 06:28:51 am
  • If it's worth doing, it's worth overdoing
Re: mdf
« Reply #2 on: February 11, 2005, 11:12:38 pm »
You're cab will be 20% heavier with 3/4".
This opinion was created from 100% post consumed information.
the3eyedblindman
  • Last login:November 17, 2006, 03:00:06 pm
  • Soon: 4 Player Mame and Scratch Built Moonwalker.
Re: mdf
« Reply #3 on: February 11, 2005, 11:15:32 pm »
3/4 inch is sturdier and t moulding fits it better, use 3/4 inch  :)
Coming soon: 4 player mame cab and Scratch built Moonwalker....Hall of Fame, here I come!
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
Re: mdf
« Reply #4 on: February 11, 2005, 11:16:15 pm »
From what I know, the majority of people use 3/4, so my suggestion, use it.
Wienerdog
Re: mdf
« Reply #5 on: February 11, 2005, 11:26:47 pm »
20%...  sorry, I was just stating the obvious.  3/4" is 20% heavier than 5/8" but your cab has lots of weight from the monitor, computer, controls, etc.  I'd honestly consider 5/8, because 3/4" is just SOOOO heavy.  A full 3/4" sheet of MDF is around 90 to 100lbs.
crashwg
Re: mdf
« Reply #6 on: February 11, 2005, 11:28:47 pm »
The density of the core is expressed as the weight of a one cubic foot (1'x1'x1') block of the material. Therefore, an MDF sheet using a 48# (pound) core, will weigh 102 pounds. (49"x97"x3/4"= 2-1/8 cubic feet)
A 5/8" sheet of the same 48# core would weigh 78 pounds (49"x97"x3/4"=1-5/8 cubic feet)
Lets say you use 3 sheets of mdf on your cab.  3/4" will make your cab weigh 306# and 5/8" will make it weigh 234#.
Only question that remains is which is more important to you, 72# or the beefyness/extra strength of 3/4".
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
the3eyedblindman
Re: mdf
« Reply #7 on: February 11, 2005, 11:35:32 pm »
if you put casters on the cab, weight wont be that big of an issue.
cholin
    • Nilok Productions
Re: mdf
« Reply #8 on: February 11, 2005, 11:36:15 pm »
Even with casters, 72 pounds is a big difference.
Witchboard
Re: mdf
« Reply #9 on: February 11, 2005, 11:38:23 pm »
Since you're building with MDF, I would go 3/4".  If you were building with plywood, I would suggest 5/8".  Just my prefs.
FractalWalk
  • Newbie
  • Last login:September 20, 2010, 06:12:37 pm
  • Life is time spent fighting entropy.
Re: mdf
« Reply #10 on: February 12, 2005, 01:05:43 am »
I used 5/8" MDF and it is plenty sturdy and T-molding is perfect.
saint ganked my avatar.
elvis
  • Last login:April 13, 2023, 05:31:03 pm
  • penguin poker
    • StickFreaks
Re: mdf
« Reply #11 on: February 12, 2005, 03:06:34 am »
Another vote for 18mm. :)
Xiaou2
  • NOM NOM NOM
Re: mdf
« Reply #12 on: February 12, 2005, 05:06:47 am »
 The thicker the better.   Mdf can be damaged easily - esp if hit on the corners.   And,  screws can easy strip if there isnt  enough depth..  (use coarse thread drywall screws.  fine threads wont hold well at all)
  You can always easily make the cab come appart into 2 sections if you are worried about moving it 'out of house' later on. (top/bottom)
 Most fighter/new-er  cabs weight a lot afaik.  Yet move farily easily by rocking them side to side.
DrewKaree
  • HAH! Nice one!
    • A lifelong project
Re: mdf
« Reply #13 on: February 12, 2005, 11:12:29 am »
The difference in weight is negligible, unless you have to lift/move it.
That's my theory on ANYTHING heavy...it's really NOT that heavy, unless you have to lift it.  ;D
cholin
    • Nilok Productions
Re: mdf
« Reply #14 on: February 12, 2005, 11:24:04 am »
Reading around, Im guessing you should do a mix of both.  It will save you money from all 3/4, but cost you a little more if you were to use 5/8.  I think that because most people use 3/4, others follow in their tracks to assure that their cabinet is okay, where realistically, 5/8 should do the job the same.  I figure that if you use 3/4 on the places it needs the most, then you should be good.  For example:
BASE = 3/4
LOWER = 3/4
UPPER = 5/8
MONITOR = 3/4 reinforced
PANEL = either depending on plexiglass and router bits available.
The only thing I would say NEEDS to be 3/4 is the base, if you design the cabinet right.  Put a few small studs in the base, attach some casters, and youre fine.  Just make sure you use some small studs on the inside for screws to catch.  Better safe than sorry right?
IMMark
  • Last login:August 05, 2016, 07:30:02 pm
Re: mdf
« Reply #15 on: February 12, 2005, 01:18:03 pm »
My choice would be for the 3/4"
It is 70 lbs heavier...your choice is that good or bad?
3/4"..sturdier..but 5/8 sturdy enough..probably.
cost..3/4" a little more...but in the big picture of the whole project, the $ of mdf...isn't where the $ goes.
My biggest reason...as long as the T-mold will fit...3/4" is more universal in  cabinet building, if you want to cap ends, add some solid wood...all 1x will match up.  Gromets, hinges, lots of acces. are available for 3/4"....
That's IMHO...good luck ;D
Voodooray
  • Last login:July 24, 2006, 04:52:41 am
  • Load ya swine!!!!!
Re: mdf
« Reply #16 on: February 13, 2005, 07:25:01 am »
Hi Gang.
I'm a relative newby to mame however, i have been a carpenter / cabinet maker for 17 years.
In my humble opinion, anything that size needs to use the thickest material you can use. 18 mm MDF is perfect for this. Although thinner MDF looks just as solid it will twist and warp if stressed too far. Also, the more depth you have to screw into the sturdier the cabinet will be.
Hope that helped, if not i'll just stand in the corner and be quiet. :-X
Voodoo Ray.
88 Acid Revival, Safe!
Voodoo Ray.
cholin
    • Nilok Productions
Re: mdf
« Reply #17 on: February 13, 2005, 12:17:51 pm »
Good thing for carpenters eh :)  I learned a lesson.
Daniel270
  • Last login:April 10, 2011, 12:34:14 pm
  • Older Than PONG!!!
Re: mdf
« Reply #18 on: February 13, 2005, 02:58:45 pm »
I Haven't Lost My Mind, It's Backed Up On Disk Somewhere.
