Main > Main Forum
Trackballs - whats the diff?
Pages: << < (6/6)
ErikRuud:
Some of the buttons are lighted.
DreamWeb:
Ok.. How did you manage to mount that without a plate on a wooden CP?
d.
cholin:
You remove the top half of the trackball casing and just mount it direct, I assume.
http://www.willcoxonline.com/mame/controlpanel/controlpanel.htm
ErikRuud:
No, No, NO!!!!!
I have mentioned it before, but My CP's are made from two layers of plywood.   The top layer is high quality 1/4" plywood while the bottom layer is 3/4" plywood.
For the joysticks and trackball, the lower layer has cutous that fit arond the controls.  The top layer only has the holes for the sticks and trackball.  This providdes a stronger mounting surface than routing out MDF would.
Stingray:
Or if you have the tools to work with metal, you could always build a metal control panel and eliminate all this fussing about with mounting plates and routing out wood.
-S
Pages: << < (6/6)
Go to full version
