Author Topic: t-moulding  (Read 977 times)
sodapopinski
  • Last login:February 12, 2011, 11:13:41 am
  • if I only had normal friends
t-moulding
« on: February 10, 2005, 07:23:27 pm »
I just found a router bit that will cut the groove for t-moulding. What size is the kerf suppose to be? the bit is about 1/8".
TalkingOctopus
  • Last login:September 06, 2023, 03:39:02 am
    • My Arcade
Re: t-moulding
« Reply #1 on: February 10, 2005, 07:34:52 pm »
1/8" is too big.  It needs to be 1/16".  Many people, including myself ordered a bit here:
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_slot.html
stellarola
  • Last login:June 24, 2020, 11:46:59 pm
  • .::For the love of the game::.
Re: t-moulding
« Reply #2 on: February 11, 2005, 12:20:50 am »
They also sell the same bit at Lowes.
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
Re: t-moulding
« Reply #3 on: February 11, 2005, 01:13:33 am »
You can also special order a 1/16" Freud bit (the best) at Home Depot. Its Called a Freud 1/6" Slot Cutter...
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
FractalWalk
  • Newbie
  • Last login:September 20, 2010, 06:12:37 pm
  • Life is time spent fighting entropy.
Re: t-moulding
« Reply #4 on: February 11, 2005, 03:39:33 pm »
Am I the only one that used 3/32". That worked perfectly for me. It holds tight but still lets me remove it without taking a pound of MDF with it.
saint ganked my avatar.
TalkingOctopus
    • My Arcade
Re: t-moulding
« Reply #5 on: February 11, 2005, 04:13:11 pm »
Anything smaller than 7/64" should work fine.
sodapopinski
Re: t-moulding
« Reply #6 on: February 11, 2005, 04:22:54 pm »
 I'm a carpenter and I was explaining my problem of the wrong slot cutter size at work when I noticed that there was t-moulding right in front of me. Its commonly used between lino and carpet. The moulding is nearly identical to the arcade machine moulding. I assume its cheap plus the moulding clearly is designed for 1/8". I plan on looking further into this because it would be a hell of alot more convenient. I've checked everywhere for a 1/16" slot cutter here in Edmonton, Alberta and nothing. Has anyone used this alternative?
FractalWalk
  • Newbie
Re: t-moulding
« Reply #7 on: February 11, 2005, 05:59:11 pm »
sodapopinski
Re: t-moulding
« Reply #8 on: February 11, 2005, 06:22:28 pm »
What about 1/8" and some really good adhesive or epoxy?
TalkingOctopus
    • My Arcade
Re: t-moulding
« Reply #9 on: February 11, 2005, 08:16:28 pm »
Sure that could work but I'd really recommend doing it the "right" way if possible.  You can use hot glue w/ an 1/8" slot.  You need an adhesive that dries quickly because tmolding does not stay in place.  You could also use small nails to pound it in or to keep it in place while the adhesive is drying.
