Arcade Collecting > Miscellaneous Arcade Talk
Building gameroom in my basement - ideas?
GGKoul:
Not sure what would case the lights to flicker, but you'll be fine as long as you have a lots of plugs wired to a 2 or 3 breakers.
DrewKaree:
When you say "flicker", do you mean the lights dim slightly, or do you mean the lights actually turn on and off for a breif half of a second?
If it's the latter, it's poor electrical work somewhere. If it's the former, that's normal, but may be improved by isolating those things further with their own breakers so they aren't drawing that large initial load of power-up juice....I dunno if you're reaching the limit of that particular breaker, or if they draw SO much at start-up that they should have their own dedicated breaker to help those things run smoother over time, as well.
RayB:
It's just the brief dimming.
DrewKaree:
That's normal, from my understanding, unless steps are taken to isolate those big power suckers from stuff like your lights. I'm betting when they wired your house (you said it was fairly new, yes?) they saved money by either running less wires and putting more stuff on larger breakers, or they tied larger items like the furnace/HVAC into less used (but capable of handling it) breakers, which happen to be tied into a large lighting circuit.
Father-in-law installed A/C on the house, separate circuit, furnace is on a separate circuit, and no problems with those, but the built-in microwave, which shared a circuit with all the upstairs electrical, did the same thing you mention every time it turned on/off, until too much stuff was plugged in and it started blowing fuses, after which he ran another circuit, and solved the problem altogether.
Wade:
--- Quote from: Trimoor on February 07, 2005, 02:28:08 pm ---Don't worry about overloading.
Navigation
[0] Message Index
[*] Previous page
Go to full version
