Author Topic: How can I mount a computer power supply in my cabinet?  (Read 3868 times)
sofakng
  • Last login:February 18, 2021, 04:19:21 pm
« on: January 29, 2005, 05:52:02 pm »
How can I easily mount a power supply in my cabinet?  Right now I have my hard drive mounted onto the side of the cabinet using l-brackets and I have my motherboard mounted onto the side using PCB mounting feet.  To mount my OLD power supply I drilled holes into the power supply itself and then used nuts, bolts, and l-brackets to mount it to the side of cabinet.
I got a new power supply and I'm trying to avoid drilling holes into it.  Does anybody have any suggestions for me on how I can mount it directly to the MDF board (eg. the side of the cabinet)?
Thanks.
missioncontrol
  • MC-Retro says Wot!
  • Trade Count: (+13)
  • Last login:May 23, 2021, 12:53:30 pm
Re: How can I mount a computer power supply in my cabinet?
« Reply #1 on: January 29, 2005, 06:16:53 pm »
perhaps you could use some metal straps......
Goz
  • KOTA
  • Last login:September 03, 2020, 02:23:18 am
« Reply #2 on: January 29, 2005, 07:23:55 pm »
The local hardware store will have all sorts of things you can use.
L-Brackets
Flashing (metal used in mounting gutters)
Theres allso a roll of aluminum stuff you can find in with the plumbing stuff that has holes in it every inch or so, this stuff is sturdy yet easily formed to shapes.
I would suggest goint to your local Home Depot, Lowes, etc and just look arround if you are in the right mindset you will start to see stuff that you can use for other applications of you arcade cabinet.
Hope it helps,
-Goz
Trimoor
  • Last login:November 18, 2006, 09:01:46 pm
  • I like shooting out of helicopters.
    • Trimoor
« Reply #3 on: January 29, 2005, 07:51:43 pm »
Velcro would also work very well. (Really, it does.)
It also serves to dampen the vibrations from the fan.  Wooden cabinets make loud sounding boards.
« Reply #4 on: January 29, 2005, 08:00:50 pm »
My PSU had some slots in the backside of it, so I could just sit it on the wood and put a few screws in.  This is all that holds mine in place - the weight of it does the rest!  You can probably just make out one of the screws in this pic (to the back/right of the PSU):
Will
  • Last login:April 08, 2012, 03:32:27 am
  • Finished Lurking.....
« Reply #5 on: January 29, 2005, 08:04:05 pm »
serial ata hard drive in your mame rig,very nice minwah...Have any heat issues from it not being in a case?
Chris
    • Chris's MAME Cabinet
« Reply #6 on: January 30, 2005, 02:05:36 am »
I used four little tabs of metal with two holes drilled into each one.  I removed the four screws holding the bottom of the power supply on, put the tabs over the holes and put the screws back in.  Now you have four tabs sticking out that you can screw to the wall of the cab.
--Chris
--Chris
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #7 on: January 30, 2005, 01:35:52 pm »
Duct tape solves all problems. (even fashion)
NO MORE!!
