Author Topic: Can I use a PS/2 spinner & a USB mouse at the same time?  (Read 1552 times)
Dougmeister
  • Last login:July 27, 2018, 05:44:52 pm
  • Dig-Doug
« on: January 24, 2005, 10:10:46 pm »
What happens when you cross:
...a PS/2 spinner with a USB mouse?
...a serial spinner with a PS/2 mouse?
(NO, this isn't a joke... no punchline coming)
I have a USB mouse w/ a PS/2 converter on it, but want to get one of TheNasty's spinners.  I can get either a PS/2 or a serial connection, but my vast experimentation (5 minutes) on 2 Windows '98 systems I have show that 2 mice cannot co-exist on a computer at the same time.
Now, maybe if you did the "Add Hardware" wizard, loaded other drivers, I dunno.
Just wondering if I can have my cake and eat it, too.
Please advise.  Thanks.
Goz
  • KOTA
  • Last login:September 03, 2020, 02:23:18 am
Re: Can I use a PS/2 spinner & a USB mouse at the same time?
« Reply #1 on: January 24, 2005, 10:29:54 pm »
Yeah it should work.
Example: Laptops with 98 usually have PS2 ports for mice / keyboard and they also have built in pointing devices.
Spinners and trackballs connected to an optipac are seen as two mice.
I don't recall there being an OS restriction, however if there was, you might be able to use a Y splitter.
-Goz
Dougmeister
  • Dig-Doug
« Reply #2 on: January 25, 2005, 09:46:37 pm »
Thanks.
Tried a PS/2 mouse on a machine that had an existing (working) USB Mouse.  PS/2 didn't work.  O/S = Win98SE.
Same thing on another Win98SE machine w/ a PS/2... added a serial and it didn't work.
Do you think I need to run the "Add Hardware" wizard or something?
NoOne=NBA=
« Reply #3 on: January 25, 2005, 10:16:01 pm »
You'll probably need to run the Analog+ version of MAME to do this.
It supports multiple mice.
quarterback
  • Last login:August 16, 2023, 10:51:41 pm
« Reply #4 on: January 25, 2005, 10:18:49 pm »
Thanks.
-- Chad Tower
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 08:37:55 pm
« Reply #5 on: January 25, 2005, 10:22:16 pm »
this can't be true. I have Win98se on  mine with ps2 mouse and serial mouse and both work, of course only one mouse pointer but my ps2 trackball can move it or my serial spinner moves it to.
You need to install your serial mouse driver, your ps2 mouse drivers.
Free VGA Breakout Cable
quarterback
« Reply #6 on: January 25, 2005, 10:37:59 pm »
« Last Edit: January 25, 2005, 10:40:17 pm by quarterback »
-- Chad Tower
penjuin
  • Last login:February 23, 2011, 03:51:58 pm
  • The penjuins are coming...
« Reply #7 on: January 25, 2005, 10:48:58 pm »
i have use dual mice on my computer (it was not for mame though) one being ps2 one being usb and they both worked, although they controled the same pointer, making it kind of annoying ;D
quarterback
« Reply #8 on: January 25, 2005, 11:38:55 pm »
XP or Win98?
-- Chad Tower
penjuin
« Reply #9 on: January 25, 2005, 11:40:17 pm »
xp sorry
quarterback
« Reply #10 on: January 25, 2005, 11:42:59 pm »
xp sorry
No problem man, I'm just trying to figure this out.
-- Chad Tower
apeekaboo
  • Last login:May 11, 2014, 01:27:41 pm
  • Debian addict
    • my MAME cabinet
« Reply #11 on: January 26, 2005, 06:10:58 am »
Using a ps/2 mouse together with a usb mouse should present no problem in xp.
Dougmeister
  • Dig-Doug
« Reply #12 on: January 26, 2005, 09:11:32 am »
Where does one acquire serial or ps2 drivers?  The computers are pieced together from various other computers ("Frankenstein syndrome"), and the mice are, well, extra mice that someone gave me.
Just use the default ones on the Win98 CD?  Via the "Add Hardware" wizard?
Thenasty
« Reply #13 on: January 26, 2005, 10:39:42 am »
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #14 on: January 26, 2005, 04:24:36 pm »
Shouldn't be (much of) a problem in 98 either.  However, you should install the ps/2 mouse first, then plug and play the USB mouse.
You might have some problems if both the drivers try to totally control all mice, but the default windows drivers that come with window should be fine.  Buttons 4+ might be missing this way, but the rest of the mice should work.
Robin
Knowledge is Power
Ravant
  • Last login:February 24, 2005, 11:47:58 am
  • Hello.
« Reply #15 on: January 27, 2005, 11:43:52 pm »
Here's a quick question... say I'm not running any version of windows... I've just stripped the PC down to a version of FreeDos and am shelling directly into a dos MAME front-end... could it be possible to have the spinner and ball connected simultaneously?
OSCAR
    • Oscar Controls
« Reply #16 on: January 27, 2005, 11:58:17 pm »
Absolutely, as long as you still aren't talking about USB!  :)
Download http://www.oscarcontrols.com/files/MOUSE.EXE.  This is a dual mouse DOS driver that works with PS/2 and serial mice simultaneously.  For the help file, type ' mouse /?' at the command prompt in the directory where you downloaded the driver.  For basic operation, all you should need is something like "c:\mouse\mouse dual".
Ravant
  • Hello.
« Reply #17 on: January 28, 2005, 01:34:33 am »
Only serial and PS/2. I refuse to submit to the omnipotence of USB yet... I'm a nostalgic psychopath that would still use a 5-pin DIN if I had the chance. Come on, I still have my TRS-80 Color Computer II. :-P
Thenasty
« Reply #18 on: January 28, 2005, 08:45:27 am »
If you find a DOS USB Driver, please let everyone know here (Shout it out loud), cause we been looking for years and can't find any USB DOS Drivers
« Last Edit: January 28, 2005, 08:54:16 am by Thenasty »
quarterback
« Reply #19 on: January 28, 2005, 10:46:20 am »
-- Chad Tower
Thenasty
« Reply #20 on: January 28, 2005, 11:12:50 am »
I have seen the USB4DOS and tried that but it don;t work w/my mouses. Did you have success using it in PURE DOS ? Which one of those is a working MOUSE USB DOS Driver ?
quarterback
« Reply #21 on: January 28, 2005, 11:23:49 am »
I've not tried any USB-DOS drivers, I had just heard/read about the Motto Hairu
-- Chad Tower
Thenasty
« Reply #22 on: January 28, 2005, 11:27:16 am »
I think this Motto Hairu are not for Mouse Drivers.
moonpatrol 4 lyfe
  • Last login:May 08, 2011, 04:32:18 pm
« Reply #23 on: January 29, 2005, 03:02:15 am »
Does mame view the 2 mice as 2 seperate devices?  In otherwords, if i'm playing warlords with Mouse A and Mouse B attached, will both A and B control p1, or will I be able to assign A to p1 and B to p2.
Thanks,
Bill
Ravant
  • Hello.
« Reply #24 on: January 30, 2005, 01:39:23 pm »
That sounds fairly logcial, as it should work. If you're using a serial port and PS/2 port, they become two seperate devices. Pointing devices or not, they're still two seperate devices. By the same logic, if they didn't work, then if I plugged my Sidewinder Force Feedback Joystick into the game port interface, and my USB Gamepad into a PS/2 interface via a USB/PS-2 converter, then neither of the devices should work simultaneously. ZSnes picks them up as two seperate devices, and can be mapped individually. So... yeah.
