Author Topic: joystick dust washers - adding felt on the bottom? (or something similar)  (Read 3883 times)
megashock5
  • Last login:May 19, 2015, 06:51:16 am
My wife actually suggested this to me, so I thought I'd see if anyone has tried this...
She wondered if adding something like felt to the bottom of the plastic dust washers would help with not scratching the overlay.
Any opinions? Thanks a lot!
SirPeale
  • Green Mountain Man
The easiest solution to this of course is to have the dust washers *under* the overlay, where they belong.
CCM
Doesn't the dust washer move with the joystick?  Wouldn't putting it *under* the overlay prevent that movement?  Or am I completely off-base?
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Look at the top of your joystick base. Some of them have a raised edge. The dust washer can fit into the lowered space on the top and still move around with the joy...
NO MORE!!
SirPeale
I worded that badly.
They don't go under the overlay itself, rather under either a piece of plexi or metal that is on top of the wooden CP.
coasternuts
  • Last login:January 11, 2010, 08:39:24 pm
  • Ouuuuch....I am not the worst game ever!!
I didn't think those dust washers would scratch the plexi.
SirPeale
He never said plexi, he said artwork.  With the way you guys usually make your artwork, after a while the action of the dustwasher on top of it would wear it away.
Stingray
It constantly amazes me at how many cabs have the dust washers on top of the CP instead of under where they belong. Of course CPs are supposed to be made of sheet metal and not a 3/4 inch thick hunk of wood too. ;) **puts on flame resistant suit and jumps for cover**
-S
ErikRuud
  • Last login:March 05, 2021, 10:20:27 am
My dust washers are underneath where they belong, although I have seen a few real arcade machines where they wer mounted on top.  There was a four player game in the trainstation that had one with the washer on top, two with it underneath and the fourth had no washer at all.
Joystick are primarily designed for metal panels.  My panel is sort of a compromise.  I use two layers to construct my panels.  The upper layer is a high grade (5 laminations or more) 1/4" plywood.  The lower layer is 1/2" or 3/4" plywood.  The joystichs are mounted to the 1/4" layer and fit into cutouts in the lower layer.  This gives a stronger mount than routing out the backside of an MDF panel as most people do.
American Laser Games Wrapper
O2em Rom Utility
SirPeale
There are games with both metal and wood control panels.  I've got an original Mortal Kombat CP that is wood.
If you saw the washers on top then likely the game was a conversion.
whammoed
  • Last login:Today at 09:05:02 am
  • Crack don't smoke itself
    • NiceMite
Re: joystick dust washers - adding felt on the bottom? (or something similar)
« Reply #10 on: January 24, 2005, 01:20:10 pm »
Yep, the two cocktails I built I put the dust washers on top without giving it a thought.  The last game I saw on location had it this way so it was stuck in my head.  I haven't got around to switching them...and I think I may hold off for a while because I've noticed they offer a bit more protection on top.  It leaves less opportunities for toddler crums to find their way inside the panel.  I have textured black panels with no overlay so it looks fine.
FractalWalk
  • Newbie
  • Last login:September 20, 2010, 06:12:37 pm
  • Life is time spent fighting entropy.
« Reply #11 on: January 24, 2005, 05:00:26 pm »
I put mine under plexi on wood (ala OSCAR) for no reason other than I think it looks better.  It allowed my a bit more freedom with my artwork as well.
saint ganked my avatar.
IG-88
  • Last login:May 09, 2023, 08:29:46 am
« Reply #12 on: January 25, 2005, 05:00:38 pm »
-HarumaN
crashwg
« Reply #13 on: January 25, 2005, 08:06:46 pm »
Not that I want to anyways, but I can't put my dustwasher under the cp/artwork...  It's a T-Stick+!  8)
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
mr.Curmudgeon
  • It's going to hurt your brain. A lot.
  • Last login:October 11, 2021, 07:15:49 pm
  • Huzzah!
« Reply #14 on: January 25, 2005, 08:16:53 pm »
AAAAAHHHHH! Stop giving me things to think about!!! AAHHHHHHH!! Washers on top, or washers on bottom....AAAAAAAAAAAAAAAAAAHHHHH!
« Reply #15 on: January 26, 2005, 05:27:30 am »
As said, some originals did have dustwashers on top...
Most originals did not use plexi...
And IMO if you have a proper CPO material the dustwasher won't wear through the artwork.
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
« Reply #16 on: January 26, 2005, 10:25:10 am »
dustwashers belong on top... every arcade i remember being in as a kid they were always on top... i dunno what u guys were smoking  :P
"Owens is the ringleader in the ass hat circus"  D K
RayB
  • There's my post
    • RayB.com
« Reply #17 on: January 26, 2005, 10:56:52 am »
« Last Edit: January 26, 2005, 10:59:18 am by RayB »
NO MORE!!
sWampy
  • Last login:February 02, 2010, 04:23:40 pm
« Reply #18 on: January 26, 2005, 11:09:35 am »
I always thought those things were put there so people couldn't get their fingers caught between the cp and the joystick, and maybe injure their poor little finger, and hire a scum ball lawyer to sue the arcade out of business.
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 08:37:55 pm
« Reply #19 on: January 26, 2005, 11:13:30 am »
Dust go under the cp if the CP is METAL. It does not look good if using a 3/4 MDF wood, it has to be on top.
Free VGA Breakout Cable
megashock5
« Reply #20 on: January 26, 2005, 11:24:23 am »
^ yeah, I'm using 3/4" MDF. If I routered a spot for the washer into the top of the wood, it would prevent the stick from moving far enough to hit the switches. (keep in mind I have no idea what I'm doing, really).
sWampy does bring up a good point about fingers. I'll consider it a safety measure for my 4 year old
Thenasty
« Reply #21 on: January 26, 2005, 11:26:36 am »
How about when player gets piss and stick a BLOB of bubble GUM in the HOLE
Shape D.
  • Last login:July 05, 2012, 06:17:57 pm
  • >Look at me, I'm a Newbie<
« Reply #22 on: January 26, 2005, 11:27:06 am »
How does the type of stick make a differance?
Hey Baby, Have you ever met a Newbie with 38 pages of previous posts before? Do you Want to?
Sephroth57
  • Poo Monkey
    • Check it out!!!
« Reply #23 on: January 26, 2005, 11:29:36 am »
i think because those are the switchable 4-8way sticks and it would interfere with the mechanism if it were underneath
« Reply #24 on: January 26, 2005, 12:08:48 pm »
Actually I think it's because the washers on the T-Stik Plus are not (easily) removable - the balltops are glued on pretty good...
mr.Curmudgeon
  • Huzzah!
« Reply #25 on: January 26, 2005, 12:12:44 pm »
I guess it's not easy, but they can come off the bottom of the shaft if you swap the stick out. Just incase others are wondering.
FractalWalk
  • Newbie
« Reply #26 on: January 26, 2005, 03:16:38 pm »
« Last Edit: January 26, 2005, 03:19:46 pm by FractalWalk »
crashwg
« Reply #27 on: January 26, 2005, 03:24:24 pm »
Lemme say it again
megashock5
« Reply #28 on: January 26, 2005, 03:44:25 pm »
Those pics make sense if you were using plexi over the wood. I'm just using an adhesive graphic overlay, so I don't know what it would stick to over the washer area. Maybe I'm just not getting it, wouldn't be the first time that happened.  :P
Shape D.
« Reply #29 on: January 26, 2005, 03:47:07 pm »
The way the T-Stick+ works is that you pull the handle vertically and then rotate the stick to switch between 4 and 8 way modes. If you put the dustwasher under the cp you wouldn't be able to pull the stick. ;)
I had thought the dust washers were looser on the sticks so it would just slide through the washer.
« Reply #30 on: January 26, 2005, 04:28:31 pm »
I thought the lower part of the shaft had a fatter section (to prevent the stick falling through the centre hole) which would not allow the wash to come off.  I might be wrong...
« Reply #31 on: January 26, 2005, 04:34:23 pm »
You can route out an area on wood big enough for full joy movement and still make it look good. Oscar shows one way to do this on his site.
What Megashock said is right.  Oscar does a great job here (as always), but he's using plexi.  He (& I) do not want to use plexi...so wood is certainly not ideal for under panel washer mounting.  The only way around it I can think of is to use a metal mounting plate mounted flush into the wood.
While I agree most classic games have the washers underneath, many newer games have washers on top.  In particular cabs which use Jap-style sticks as these (usually) do not have the recess that Happ sticks have - I expect you could get around this by spacing the sticks down slightly with washers.
versapak
  • Somewhere between a block of wood and a monkey
  • Last login:August 16, 2020, 02:42:43 pm
  • I am t3h GAY!!!
« Reply #32 on: January 26, 2005, 04:58:36 pm »
It never occurred to me to mount them underneath the plexi, but I don't think I would like it like that anyway, since I don't have any CP artwork to hide the disc, and
« Last Edit: January 26, 2005, 05:21:37 pm by versapak »
Shape D.
« Reply #33 on: January 26, 2005, 05:04:22 pm »
I also like to spin it. I imagine that certainly doesn't help the look of the plxi, but what can ya do?  :D
Not spin it.
versapak
  • I am t3h GAY!!!
« Reply #34 on: January 26, 2005, 05:23:27 pm »
Not spin it.
One would certianly think that would be an option, but I have found that it is actually not doable.
I am just too figity a person I suppose.   ;D
:P
SirPeale
« Reply #35 on: January 26, 2005, 05:50:53 pm »
I should write a tutorial the way I did it.  I did it almost the way Oscar did it, except I routed an area for squares of plexi over the joystick area, instead of a sheet of plexi on the entire CP.
As for  real control panels, I have a Mortal Kombat CP I should take a picture of.  It's got 3/4" wood/MDF, and the dust washers are mounted right under a sheet of metal that's on top, and the area underneath has been routed out.  I don't know if it covers the entire top or not, though.
FractalWalk
  • Newbie
« Reply #36 on: January 26, 2005, 06:05:18 pm »
Shape D.
« Reply #37 on: January 26, 2005, 06:23:33 pm »
I'm guessing because its easier to find a thin sheet of metal than plexi.
« Reply #38 on: January 26, 2005, 07:37:01 pm »
Actually I was thinking more that I could mount a stick directly to metal, but couldn't to plexi.  Also Oscar used T-nuts, but I was planning to just use carriage bolts (they probably would crack the plexi or just not hold as well as in metal).
My only other concern is that I'm not too keen on working with plexi...but that's my problem  :D
I'm not sure what I will do when it comes to it...I might try the metal idea just to see if it works & looks OK.
Peale:  I'd be interested in seeing your MK panel if you can get any pics - sounds like pretty much what I was thinking.  I would probably just use small plates of metal for the sticks sunk into the wood.
FractalWalk
  • Newbie
« Reply #39 on: January 27, 2005, 12:12:14 am »
