Author Topic: Free Gem  (Read 1155 times)
IG-88
  • Last login:May 09, 2023, 08:29:46 am
Free Gem
« on: January 22, 2005, 03:48:30 pm »
Did a search for this but didn't have much luck. Does anyone know if there is a MAME build for this O/S? Or if there has been some talk of it on this forum?
-HarumaN
shadowdrak
  • Last login:November 20, 2005, 04:59:54 pm
  • I'm still a llama!
Re: Free Gem
« Reply #1 on: January 22, 2005, 04:47:37 pm »
not one I can find.  You could port it yourself though :)
IG-88
Re: Free Gem
« Reply #2 on: January 22, 2005, 04:51:50 pm »
-HarumaN
shadowdrak
Re: Free Gem
« Reply #3 on: January 22, 2005, 06:09:00 pm »
That was a joke more than anything.  If you aren't experienced in programming for both windows/dos and freegem, you can pretty much forget it.  Besides that it is a "simple" as changing all of the dos or windows specific stuff to gem stuff.  Not exactly easy per se but do-able if you have the time.  That is assuming you can get it to compile under gem.  Has gcc been ported to gem?  If not, you have to try to get it to work on another compiler as well.
elpresidente
  • Last login:May 04, 2012, 10:06:30 am
Re: Free Gem
« Reply #4 on: January 22, 2005, 09:36:23 pm »
What is freegem and why would you want to run mame on it?
IG-88
Re: Free Gem
« Reply #5 on: January 22, 2005, 09:59:23 pm »
Well..., from what I understand it's an OLD O/S that was around way before windows and is actually still being worked on. I've just started learning about it myself but I guess it's supposed to be pretty small, fast and efficient. I thought it may be something of interest to use for a MAME cab. I dunno.
-HarumaN
elpresidente
Re: Free Gem
« Reply #6 on: January 23, 2005, 10:23:50 am »
Yeah. I googled it and saw some screenshots. Wasn't real impressed but they're only screenshots. I would think that someone wanting a custimized, fast, and lean mame cab would do better with Linux or Dos. Even Windows can be made to be quick and lean.
