Main > Main Forum
Happ Perfect 360's and power supply
Pages: << < (2/2)
Thenasty:
--- Quote from: Taborious on January 21, 2005, 03:15:17 pm ---I was told that the Happ 360 could connect to a regular encoder, like the IPac4 and you didn't specifically need an optical encoder, that true? I am contemplating the 360's but still on the fence...
have you seen my pooormans diagram above ?
Will:
I have an I-pac 4 and i see no connections for power.My plan had been to run a wire from my power supply.Can anyone confirm if the ipac-4 has 5v that can be used?
Thenasty:
here
Will:
in the immortal words of homer simpson "DOH" .What kind of connector should I use for those pins,just normal quick connects?Thanks nasty.
Thenasty:
you only need 2 of those pins (check the site which ones). Use an extra cable from a CASE that hooks up to the LED, RESET, SPEAKER etc.. of the motherboard.
Pages: << < (2/2)
Go to full version
