| Main > Main Forum |
| 27" Cocktail |
| << < (2/2) |
| IG-88:
Looks sweet! Add some more background lighting when you snap your next pics, that way we can see more details! |
| NoOne=NBA=:
The guts don't matter. If you ever saw the inside of MY cab, YOU'D probably laugh. I've got wires going EVERYWHERE in there. Fortunately, most of my wiring is done with Cat-5 cables, so it's all mostly bundled. Your cab looks great. The one thing I noticed about it though is that the monitor bezel seems to stick up above the table top. Are you planning to add cocktail glass over the top? If so, you may need to rout the monitor bezel into the top, to get the glass to sit flush. |
| solfood:
the bezel is sitting on some black foam rubber insulation that help keep out the light from the blue leds fans on either side. When the lights in the loft were off it was bleeding through the sides of the bezel and was annoying me. once the glass is sitting on top it will be flush with the top. here's another picture of the outside....it's amazing how much better you can see the color with some lights and the flash on. |
| IG-88:
I love it. Right out in the middle of the room too. Awesome! |
| solfood:
yeah well...that blue ethernet cable you see in the picture would quite reach all the way to yonder wall. once newegg delivers the wireless adapter the thing will sit under that Pollock Phish print on the wall. My wife had to coordinate the colors to mach the print. she's crazy like that. |
| Navigation |
| Message Index |
| Previous page |
