Author Topic: strange hard drive problem *happy to say problem now fixed*  (Read 2437 times)
Layer01
  • Last login:February 28, 2005, 03:42:40 pm
  • no ghost, just a shell
« on: January 15, 2005, 01:44:25 am »
ok just came back form the pc fair and now have my mame computer up and running, BUT!!! one thing is bothering me, i got a 200gig seagate HDD and whne i started the whole formatting thing it onlt came up as 139-ish gig  and now that its formatted and windows is running it says it only has 127gig (fair enough i know windows gives its self a fair bit of room so that doesnt bother me) its just that it seems to be missing a lot of the 200gig's i paid for. now i know HDDs are like that  >:( , they say one size but in effect are another but this seems like a  big difference to me  ???
so is this normal (see the biggest drive i've ever owned has been 80gig, and that was in fact 75 gig)
EDIT:
Problem solved *yay*  ;D
« Last Edit: January 20, 2005, 09:38:50 pm by Layer01 »
Bones
  • [Moderator]
Re: strange hard drive problem
« Reply #1 on: January 15, 2005, 02:13:44 am »
Are you running XP?
Layer01
« Reply #2 on: January 15, 2005, 02:16:52 am »
yep, xp the works.... i did a little research ala google, and  seems i'm not alone in my woes, so know at least i have  a few things to try out, suposedly i'm to type diskmgmt.msc and see if it sees all 200gig, if it does yay, if not, dun dun dun....
Silver
  • Last login:February 17, 2024, 10:29:00 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #3 on: January 15, 2005, 02:40:37 am »
Assuming you are using the IDE port on your motherboard, it could well be that this only supports drives up to 140gig (approx). You would probably need either a new motherboard or a IDE pci controller (cheaper) to access the full 200gig, if this is the case.
Most modern motherboards do not have this issue.
Also, type in the model of your HD in google to make sure that it is a 200gig drive.
Goz
  • KOTA
  • Last login:September 03, 2020, 02:23:18 am
« Reply #4 on: January 15, 2005, 02:40:54 am »
What motherboard are you using? Earlier mobo's had limitations on size that it could recognize. If memmory serves it was somewhere around 133GB. This plus the dreaded 1024 vs 1000 MB = 1GB misnomer could cause some confusion.
-Goz
rdagger
« Reply #5 on: January 15, 2005, 02:43:49 am »
You should try formatting the drive with Seagate DiscWizard:
http://www.seagate.com/support/disc/utils.html
krick
  • Last login:February 08, 2023, 08:30:27 pm
  • Gotta have blue hair.
« Reply #6 on: January 15, 2005, 02:48:58 am »
The limit is 128 *true* gigabytes.
This is equal to approximately 137 *advertising* gigabytes.
This limit is imposed by the ATA LBA32 addressing scheme.
To get past this limit, you need both hardware and software capable of addressing using LBA48.
This is why most large retail drives shipped with their own IDE interface cards when they first came out.
More info available here...
http://www.dewassoc.com/kbase/hard_drives/hard_drive_size_barriers.htm
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
Layer01
« Reply #7 on: January 15, 2005, 04:23:16 am »
whoa! is there anything you guys dont know lol  ;D
well my mobo is fairly new i assume since its socket 754 (running AMD athlon 64 2800+) it has PCI slots so i would assume it would be fairly new...
but maybe it is this IDE thing... as this is the first time i've built a Pc from scratch so it is possible i screwed up somwhere there....see i have two IDE slots on the mobo and i atm have IDE 1 running to the DVD rom set to slave, and IDE 2 on the HDD which i am not sure but i have  a feeling its also set to slave, well i left it on whatever it was on when i opened it ( bad text art here --->  I {I} III  i think this was what it was on and seeing as it had 4 pins not 3 i left it  in case i busted it or somthing.)
i've tried Partition magic and that diskmgmt.msc and both showed it at 130 gig max size 127 actually available to the OS.
the mobo is a ASUS K8V-X
the HDD is  a SeaGate Baracuda 200gig HDD model num: ST3200822A (though it might have been 8T320022A couldnt quite see if it was  aS or an 8 but i think it was an S)
in the mean time i will check out ythose links
EDIT: dont know if this makes any diff, i would not think it would but i ahve not yet bothered to add SP2
crashwg
« Reply #8 on: January 15, 2005, 04:53:30 am »
My buddies wife just got a 200gb HD not too long ago and had the same problem.  She contacted the guy who sold it to her, who is a computer repair guy, and he told her that she needed to upgrade to service pack 2...
Unfortunatly for her she is unable to do that because she's running Windows XP Pirate Edition.
Anyways, hope that helps.  Don't take my word for it either, remember I'm the third person in this game of Telephone!
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
Goz
  • KOTA
« Reply #9 on: January 15, 2005, 06:36:02 am »
Some drives such as Toshiba's / IBM's have a bank of jumpers that determine the size of the drive.
-Goz
Layer01
« Reply #10 on: January 15, 2005, 07:29:28 am »
uugh after reading a fair few forums i think i now know what i have to do, or at least have a good idea of what i have to do.
i think these are my options
-take out the HDD, put it into another PC with sp1 and format it format it there using the various tools.
-replace my win xp "ultra edition"  ;) with my win xp home edition and upgrade it to sp1 and try to do it from there, but i suspect it will only see it as 127 gig as its formated like that from the bios.
-get a smaller drive (like 10gig) with only OS stuff on it, and format the big one then...
-or probably the best/easiest solution, take it into a PC repair shop and ask them if they know any easy ways to fix it, with a bit of luck they will be able to do all the hard work for me hehehehe  ;D
so unless its some mobo thing which i doubt, then i will have to do some drive jugeling and try to format it some way, or let the shop guys do that for me and save me the bother of taring my other PC's apart...
Harry Potter
  • Smite-bait
  • Last login:December 09, 2018, 04:45:32 am
  • Sober until banned. Can post but still can't read.
« Reply #11 on: January 15, 2005, 07:35:16 am »
Try this:
Then download the Reg48bitLBA for Windows XP SP1 and Windows 2000 SP3 thingy.
Hope that helps.
« Last Edit: January 15, 2005, 07:38:27 am by bosss7 »
Now in a tasty new flavour.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #12 on: January 15, 2005, 09:21:22 am »
I just installed a 160 gig Seagate drive. I did what seemed most sensible... I USED SEAGATE'S SOFTWARE!
Download DiscWizard. One of the steps it does is it detects whether your system is set up to handle larger than 139gb or not. If not, it makes the required registry changes for you (no need for switching computers or downloading special patches or anything like that). I have XP Pro, and also tested the drive in XP Home.
~Ray B.
NO MORE!!
elpresidente
  • Last login:May 04, 2012, 10:06:30 am
« Reply #13 on: January 15, 2005, 10:06:35 am »
A bios flash may work too. This is on Asus' site:
http://www.asus.com/support/download/item.aspx?ModelName=K8V-X&Type=All&SLanguage=en-us
You could try the latest bios release there.
Make sure you read the instructions on how to flasht he bios:
http://www.asus.com/support/english/techref/bios/intro.aspx
Layer01
« Reply #14 on: January 15, 2005, 09:19:19 pm »
~Ray B.
unfortunatly i can not use the diskwizard yet as the 200 gig hdd is my only drive and it would not let me reformat the same drive as you boot drive, which makes sense really  :P
i will look into the bios though, although most likely i'll just get a tiny 10gig hdd for windows and then format the 200gig from that.
i'd rather keep the 200gig free of windows madness anyhow so it'll be a good thing in the long run.
Jollyrob1
  • Last login:January 16, 2005, 10:39:28 pm
« Reply #15 on: January 16, 2005, 02:11:31 am »
You all are waayyy overcomplicating this:
You need to A)
« Last Edit: January 16, 2005, 02:14:17 am by Jollyrob1 »
krick
« Reply #16 on: January 16, 2005, 02:57:48 am »
There is no such thing as ATA166.  At least not in any currently available products.
The highest is currently ATA150, that is a Serial ATA specification.
You are correct about creating multiple partitions less than 137GB.  That will work.  However, you will most likely need to use the software provided by the drive manufacturer to create the partitions.
To see the whole drive as one partition, it all comes down to LBA48 support.
Here's the Microsoft page describing large disk support in Windows 2000...
http://support.microsoft.com/kb/305098/EN-US/
Here's the Microsoft page about Windows XP...
http://support.microsoft.com/default.aspx?scid=kb;en-us;303013
Hantarex Polo 15KHz
Layer01
« Reply #17 on: January 17, 2005, 12:03:12 am »
You need to A)  Buy a more recent mobo with ATA166 support
                    B)  Buy an ATA166 IDE controller card
                    C)  Install sp2 for Windows XP (which is what I did)
                    D)  Create more partitions, each less than 137 Gigs
You'll get darn close to the full 200gb, don't worry, the big bad hardware business is not trying to rip you off on your storage, for me, it's something like 192 gigs rougly, not sure off hand, on my laptop at present
PS: I think it's 166...   :)
thats not really an option as i just bought my mobo, and am not about to go back out and spend another "whatever it costs" just for a new mobo on the off chance that it fixes my problem.
i will instead read through the xp article link from kirck and then most likely use seagate diskwizard on the drive from a smaller drive (10-20gig) which will run win xp home sp2 and then will upgrade itself after all that is done to xp *cough* pro
and hopefully that will solve all this mess  :)
XtraSmiley
  • Last login:April 06, 2024, 09:29:46 pm
  • Kill the Big Dog
« Reply #18 on: January 17, 2005, 02:29:49 am »
It seems the easy thing to do is reformat and kick in the partition.  If you need a way to upgrade to SP2, shoot me a PM.
hearingprotectionBIGDOG@yahooBIGDOG.com
Kill the Dog man.
lucindrea
  • Last login:July 28, 2005, 10:06:19 am
  • I dont think I'm a llama!
« Reply #19 on: January 17, 2005, 10:44:15 am »
does the mb even see 200mb on the HD? if it only sees 137 , then everything else will be just a hack , if it only sees 137 , odds are you can flash the bios to fix that , then what you need is either xp with sp2 cdr , OR look here http://www.theeldergeek.com/slipstreamed_xpsp2_cd.htm and create your own xp with sp2 on it.
Layer01
« Reply #20 on: January 17, 2005, 06:44:02 pm »
yeah the mobo only saw it as being ~137 gig, i would try flashing the bios but when i goto the link with the guide on how to do it (http://www.asus.com/support/english/techref/bios/intro.aspx)
it has a few options for which manual to look at, with links like this one :
# Motherboard - AFLASH BIOS Update Procedure (For A7A, A7M, A7S, A7V, P2, P3, P4B, P4S, P5(socket 7), TU, TX97 Series)
and i have no idea what all this A7A, A7M, AFLASH stuff is all about and just dont want to screw it all up by choosing the wrong bios tute  :-\
pointdablame
  • Last login:November 09, 2023, 09:11:07 pm
« Reply #21 on: January 17, 2005, 11:51:24 pm »
are you formatting hte hdd with Fat or NTFS?
first off your and idiot
Layer01
« Reply #22 on: January 18, 2005, 12:51:21 am »
NTFS
and does anyone know how i can find out which mobo version i should use ? in regards to the flashing the bios tutes over at
here is the new bios page if that helps
krick
« Reply #23 on: January 18, 2005, 01:06:26 am »
When you say that the "the mobo only saw it as being ~137 gig", what do you mean?
Where did you see the size listed?
Hantarex Polo 15KHz
ErikRuud
  • Last login:March 05, 2021, 10:20:27 am
« Reply #24 on: January 18, 2005, 03:24:07 pm »
I recently installed a 200Gig Western Digital drive.  I could not get pas t the 133Gig limit until I downloded and ran WD's equivalent to DiscWizard.  I strongly reccomend that you use the SeaGate DiscWizard.
Burn it to a CD and then boot your PC from you windows install disc so that you are not trying to reformat the boot disc.
American Laser Games Wrapper
O2em Rom Utility
RayB
  • There's my post
    • RayB.com
« Reply #25 on: January 18, 2005, 03:56:10 pm »
Just so you know, I think DiscWizard applies the >137 fix before it does anything else. So it shouldn't matter that that is the only drive in there... Apply the fix, then you should be able to create a 2nd partition in the unused area of the disc.
ALSO, Seagate has a DOS Floppy version of Discwizard. You could use that.
http://www.seagate.com/support/disc/drivers/discwiz.html
NO MORE!!
Layer01
« Reply #26 on: January 18, 2005, 05:52:17 pm »
as in when i first started up the pc, and it was finding the hard drives available it found a ~137gig HDD i say "~" because the number was written out in megs or something so the number was something like 139756 but i cant be sure of that as its only from memory.
as for using disk wizard i will do so in about 1-2 days as i have just bought a 10gig HDD of ebay to run my OS so there will no longer be any problems with it being formatted, even if i could get arround it being formatted i will be doing so now any way to get rid of xp on it.
so thanks for your help, the only other thing i am lost on is the mobo bios flashing thing. still dont know how i can tell which tute i should be reading...
anyway i'll let you all know if disk wizard worked for me soon  :)
krick
« Reply #27 on: January 18, 2005, 06:11:11 pm »
The latest BIOS for the K8V-X is version 1006.
According to the ASUS website, your motherboard features "ASUS EZ Flash".
Hit Alt-F2 to enter the EZ Flash menu and find out what BIOS version you currently have.
If it's older than 1006, you can download the 1006 BIOS, put it on a floppy disk and follow the instructions on this web page...
http://www.asus.com/products/mb/ezflash.htm
Hantarex Polo 15KHz
