Main > Main Forum
Yoke USB Hack Question
rdagger:
--- Quote from: gobuchul74 on January 10, 2005, 08:16:23 pm ---Yeah, I've tried using the zone setting to calibrate it, but that is'nt cutting it very well.
gobuchul74:
I'll try replacing the pots. They are both 5K and look like original arcade pieces (They're marked "Long Life"). it sort of makes sense, I've begun to notice the pots sometimes 'jump' without being moved, so they might just be worn out. Thanks
unclet:
Did you take apart the yoke for cleaning?
gobuchul74:
This model has no gears in it. I believe all of the Hydra yokes were like this.
1UP:
You will need to do some tweaking with Mame settings to get it to center correctly. Adjust the sensitivity high enough that you get a full throw, but not so high that the accuracy suffers. It will take a little experimentation.
