Author Topic: How do I hack a dreamcast controller.  (Read 594 times)
stellarola
  • Last login:June 24, 2020, 11:46:59 pm
  • .::For the love of the game::.
« on: January 09, 2005, 10:19:11 pm »
Hey guys I'm kinda in need of knowing how to hack a dreamcast controller. I looked on DC2Jamma and it says to scratch away the certain parts of the buttons. The thing is I want someone to explain this to me like I'm a child...I even wanna know how the microswitch works with the arcade buttons.
Q: Do I only have to solder one wire to each button on the hacked pad?
Q: How does a microswitch work?
Below is a picture of the button and switch. What does COM1, N03 and NC2 stand for and what do they do??
« Last Edit: January 09, 2005, 10:23:42 pm by stellarola »
Hiub1
  • Last login:June 05, 2011, 11:43:25 am
  • www.sleepyjack.com
Re: How do I hack a dreamcast controller.
« Reply #1 on: January 09, 2005, 10:23:36 pm »
Well, you could save yourself the trouble and send them to me if you'd like, if not I will explain everything in detail. I am just trying to save myself the trouble if I have to type everything. :P
stellarola
« Reply #2 on: January 09, 2005, 11:38:25 pm »
nevermind i got it. :D
Raven..
  • Last login:June 29, 2021, 12:51:50 am
« Reply #3 on: January 09, 2005, 11:41:48 pm »
Honestly, you'd really be better off having Hiub1 do them for you.
TalkingOctopus
  • Last login:September 06, 2023, 03:39:02 am
    • My Arcade
« Reply #4 on: January 10, 2005, 02:04:46 am »
Here is a sega dc controller that is marked up where you need to connect wires to the buttons.
http://webpages.charter.net/rbecker5/images/dc.gif
Yes but you also need to connect one wire to the ground on pad that daisy chains to every button.
Lilwolf
« Reply #5 on: January 10, 2005, 10:15:00 am »
or you can have it done by others... I suck at hacking (my last try at a mouse killed 3 before I finally bought 2 from Oscar)
note:  he is having troubles finding more joysticks at the moment... but he will use yours pretty cheap.
http://forum.arcadecontrols.com/index.php/topic,28955.0.html
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #6 on: January 10, 2005, 06:01:46 pm »
Stellarola, do you realize that BYOAC is has many FAQs on these simple concepts (arcade controls)?  Do you see a vertical list of FAQ's on the left side of your screen (with different colored buttons)?
If you don't see the faqs, then you may have linked directly to the arcadecontrols.org forum (which is different than the arcadecontrols.com website).  Go to the homepage (www.arcadecontrols.com and click on the "Controls" button on the left, then click on the "button" section for a detailed description (and pics) of microswitch buttons.  There are FAQ's on every other area of arcade controls including Game Consoles (dreamcast hacking) and monitors, and cabinet construction.
I find it surprising that most people don't even know the rest of this great site even exists.
