Main > Main Forum
Player's Choice Games- Split Screen?
StephenH:
There is a single monitor PC-10 board, but MAME does not emulate it directly. I have heard a few reports of custom compiling MAME to enable it.
Additionally, if you want single screen, you can use the NES Versions with an NES Emulator such as FCE Ultra, RockNES, LoopyNES, FwNES, etc.
Thenasty:
--- Quote from: StephenH on January 09, 2005, 11:25:00 pm ---There is a single monitor PC-10 board, but MAME does not emulate it directly.
BSR:
It's possible to display only the lower half of the screen using AdvanceMAME.
You need to define a resolution of 256x240 (half the vertical resolution of 480).
You'll need to set the display_resize to none and you'll want to use the display_skiplines command to automatically scroll to the lower half of the screen.
Then you might want to set the game to freeplay so you don't need to worry about the timer.
Also, you can use AdvanceMAME's script commands to select the game automatically since the selection screen won't be visible.
Flinkly:
oh my $#&*!!!! a newbie who has the best answer....
i've never seen a situation where this has occured...then again, i haven't even been around for a year, maybe i should just get over it.
iwillfearnoevil:
--- Quote from: Flinkly on January 11, 2005, 05:23:16 pm ---oh my $#&*!!!!
