Author Topic: confusing about making pc to jamma arcade..  (Read 1145 times)
alundra
  • Last login:February 02, 2009, 09:30:05 pm
« on: January 08, 2005, 09:21:01 pm »
i started reading about this for the past few days, and there are something that i didnt understand enough and kind of confusing, hopefully some here can clear this up for me..
first, is the Jamma harnest, Jamma edge connector and fingerboard are the same?
second, every guide i have read, it said connect all the controls, speaker, and monitor to the fingerboard, but then where the fingerboard need to be connected to..is it Jamma PCB that the fingerboard need to be connect to? , ive try to search for the motherboard but all i found are the Jamma game boards(like pacman, galaga.ect..).. where i can buy this..thanks
« Last Edit: January 08, 2005, 11:15:57 pm by alundra »
krick
  • Last login:February 08, 2023, 08:30:27 pm
  • Gotta have blue hair.
Re: confusing about making pc to jamma arcade..
« Reply #1 on: January 09, 2005, 12:07:33 am »
Generally, you hook your joysticks and buttons, speaker (mono), coin switches, power, etc... to the JAMMA wiring harness.
All the wires in the harness end at one big wide 56 pin connector (28 on each side) called (not suprisingly) a JAMMA connector.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
alundra
« Reply #2 on: January 09, 2005, 12:29:18 am »
im still confusing..what about the fingerboard for? the fingerboard and the JAMMa harness looks pretty the same..and why most guide ive read said the fingerboard was require instead of the harness..?
fingerboard
Jamma harness
and about the "real arcade game board"..so this is the common board on all the jamma cabinet? i want to know where to buy this thing...thanks
« Last Edit: January 09, 2005, 12:43:04 am by alundra »
krick
« Reply #3 on: January 09, 2005, 12:45:45 am »
The picture you posted of a "fingerboard" actually shows the fingerboard plugged into a JAMMA harness.
A fingerboard is just a small piece of circuit board with conductors in the right spot to mate with a JAMMA harness.
Hantarex Polo 15KHz
alundra
« Reply #4 on: January 09, 2005, 01:04:00 am »
thanks..but more confusing...you said the fingerboard i posted was already plug into the jamma harness...but how come its cheapper than the Jamma harness alone..should it be more expensive than the Jamma harness because it has the fingerboard connected to it..
if i want to play all the mame and emulator games, then that mean i have to use the fingerboard? and i have to solder all the controlls and buttons input to that exposed pins on the other side of the fingerboard right?
and about the board, so i can buy any jamma game board to use it on my cabinet..and just plug the end of the harness connector into the edge of the board then i can play all the mame and emulator i want..?thanks
Goz
  • KOTA
  • Last login:September 03, 2020, 02:23:18 am
« Reply #5 on: January 09, 2005, 01:13:02 am »
Here is a link to an ebay Buy It Now (not mine)  that is a completely pre-wired with all the right connectors already attached and ready to go.
Hope it Helps,
-Goz
krick
« Reply #6 on: January 09, 2005, 01:25:57 am »
That picture is for illustration only.
Hantarex Polo 15KHz
alundra
« Reply #7 on: January 09, 2005, 01:45:35 am »
thanks alot..thing get clearer for me from that picture to drew..so if i want to play mame and other emulator..then i just need to hook the Jamma harness into the Jpac..and if i want to play the real arcade..then i switch the the arcade game board (pac man) and plug into the Jamma harness...i always thought that the cabbinet itself is like a console system (which have main motherboard to read all the games) and the arcade game boards is like the game cardridges...
krick
« Reply #8 on: January 09, 2005, 12:56:44 pm »
Some systems like Neo-Geo and the Capcom CPS system actually are like consoles that take cartridges.  However, most are not.
Hantarex Polo 15KHz
alundra
« Reply #9 on: January 09, 2005, 03:59:13 pm »
if i buy one of the neogeo or cps system, can i connect my computer to it to play mame and other emulator? thanks
krick
« Reply #10 on: January 09, 2005, 04:15:03 pm »
The Capcom and NEO-Geo sytems are just like any other JAMMA game board except they have a cartridge system on them.  To change the game, you just swap the cartridge instead of swapping the whole board.
You cannot connect your computer to either of them.
Hantarex Polo 15KHz
microwrx
  • Last login:July 06, 2008, 09:22:02 am
« Reply #11 on: January 09, 2005, 04:27:34 pm »
And remember that not all arcade game boards are JAMMA.  JAMMA is a standard that was devised some time after many of the older games were released and those older games (Pac-Man being one) have their own wiring setup.  Generally (but not always) each manufacturer had their own wiring standard until JAMMA came out.
krick
« Reply #12 on: January 09, 2005, 04:31:30 pm »
...those older games (Pac-Man being one) have their own wiring setup...
My bad.
I thought Pac-Man was in the JAMMA era.
Ooops!
Hantarex Polo 15KHz
alundra
« Reply #13 on: January 09, 2005, 04:35:14 pm »
i dont see how we cant connect our pc to a neogeo system, since the only difference between them is  the stereo and the and the -5V
paigeoliver
  • Awesome face!
« Reply #14 on: January 09, 2005, 04:41:56 pm »
Generally games 1986 and newer are JAMMA.
There are some exceptions.
Almost NOTHING from Sega is JAMMA except for Clutch Hitter and Bloxeed.
Atari had a lot of "sort of jamma" titles. Like that pirate game (can't recall the name), worked fine in a JAMMA cabinet, unless you pressed the start button which would crash the game (it used the action buttons to start instead).
Don't trust any games without joysticks to REALLY be JAMMA. A lot of them fall into the category of "sort of jamma". A "sort of JAMMA" game will power and display in a JAMMA cabinet, but might have control pins different for NO REASON.
alundra
« Reply #15 on: January 09, 2005, 04:49:53 pm »
can u explain more about why those neogeo cabinet cabinet cant connected to the pc..cant i just wire all output from the Pc to the neogeo Harness just like the Jamma harness?
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #16 on: January 09, 2005, 06:01:23 pm »
I guess what he's asking is, is Neo Geo JAMMA? I think so....
NO MORE!!
iwillfearnoevil
  • Last login:February 13, 2010, 07:08:43 pm
« Reply #17 on: January 09, 2005, 06:24:58 pm »
there is nothing on the computer to wire them directly too. you need a keyboard encoder. you will plug your harness right into the j-pac. not sure if you have to rewire sound (like will it work but not sound good). but your best bet is j-pac and arcadevga if you want ease of setup. the j-pac includes a cables that connect your keyboard (or usb port) into the j-pac along with a video cable to connect your computer's video card to the j-pac. you can skip arcadevga if you want to save money and do something like run advancemame in dos. see http://easymamecab.mameworld.net/html/hardware.htm for a list of older video cards that work fine.
Goz
  • KOTA
« Reply #18 on: January 09, 2005, 07:08:19 pm »
The STV Titan games run on SEGA hardward similar to the Sega Saturn and take carts similar to Neo Geo MVS and that PCB is JAMMA.
-Goz
alundra
« Reply #19 on: January 09, 2005, 07:49:50 pm »
these two pinout look pretty the same..http://solvalou.orgdns.org/tomsnew/pinout_jamma_mvs.html
so i guess connecting a pc to jamma cabinet is pretty much the same thing for neogeo cab..and just ignore the -5V
« Last Edit: January 09, 2005, 07:53:49 pm by alundra »
Goz
  • KOTA
« Reply #20 on: January 09, 2005, 08:03:52 pm »
I recently acquired a NEO-GEO MV-1FZ PCB (the mini one) and I just plugged it into my JAMMA cab and works beautifully and has stereo sound. I've ordered a Multi-Jamma board from Clay. When it arrives I'll let you know how well it co-operates with my J-PAC in my MAME cab.
-Goz
microwrx
« Reply #21 on: January 09, 2005, 11:29:38 pm »
