Main > Main Forum
Another Soldering question
Pages: << < (3/3)
ChadTower:
Ken's got it pretty much on the head, from what I'm experiencing... I may have wrecked this tip by filing it.  Oh well, I needed to get a conic tip anyway.
--- Quote from: Ken Layton on January 06, 2005, 06:50:15 pm ---You need a moist tip cleaning sponge always nearby. I wipe my tip on the sponge each and every time I solder something.
Iron clad tips need frequent wiping off while old plain copper tips need to be filed clean with a file. Never file an iron clad tip or you'll destroy it.
The tips will frequently work loose a tad during use and you must make sure the tip is secured tightly to the soldering iron.
Thenasty:
since we are talking about soldering Irons, any1 here seen the commercial about a Soldering iron that get HOT in an instant and get COLD asap. I mean you can solder something then the next second you can put your finger and not get burn. If any1 has this, how do you like it ?
Here it is, found the www page.
https://www.asseenontvnetwork.com/vcc/coldheat/coldheat/115802/
SirPeale:
Wow, I can't believe it's back.
General concensus: it's absolute crap.  It has some practical application, but for the most part it's ka-ka.
ChadTower:
Okay, I'm noticing something after a couple hours doing this... this may be revealing the source of my problem, but is it bad to get solder on the tip of the iron?
NoOne=NBA=:
--- Quote from: ChadTower on January 06, 2005, 09:04:43 pm ---Okay, I'm noticing something after a couple hours doing this... this may be revealing the source of my problem, but is it bad to get solder on the tip of the iron?
It shouldn't build up on the tip.
If it's working properly, and you are wiping it on a damp sponge regularly, you should have a REALLY THIN layer of solder on it--which should be bright silver when you finish wiping it.
Pages: << < (3/3)
Go to full version
