Author Topic: Initial startup failure  (Read 721 times)
Beeeph
  • Last login:October 18, 2006, 12:31:44 pm
« on: January 06, 2005, 03:10:46 am »
While I'm troubleshooting, I'd like to hear what others think the problem might be.
« Last Edit: January 06, 2005, 03:23:21 am by Beeeph »
Beeeph
Re: Initial startup failure
« Reply #1 on: January 06, 2005, 04:19:36 am »
Ok, it turns out it was a wiring problem.  So now that I can get it stay on, it won't P.O.S.T.  Any things I should check right off the bat?  I've reseated the RAM and the CPU, but I'm not really sure what else I should check.  Thanks!
ras2a
  • Last login:November 19, 2016, 02:21:26 pm
  • I drink, therefore I am!
    • Nolij
« Reply #2 on: January 06, 2005, 05:05:30 am »
Try resetting the CMOS - Flip the button cell out, wait a few moments and replace!
Craig
Oddfeld
  • Last login:March 06, 2021, 07:04:15 am
  • I was Jeff Minter's llama!
« Reply #3 on: January 06, 2005, 05:36:38 am »
Do you have the case speaker hooked up properly? When it POSTs it should give a series of beeps that tell you whether it's freaking out about RAM or fan failure or whatever so you can at least narrow it down a bit - see your motherboard manual (go download a copy from the mobo manufacturer's website if you've lost it).
whammoed
  • Last login:Today at 09:05:02 am
  • Crack don't smoke itself
    • NiceMite
« Reply #4 on: January 06, 2005, 09:45:54 am »
You can also try removing everything from the pc that is not necessary to see the bios.  i.e. take out any cards (besides graphics) , hard drive, floppy , usb, etc.  All you need to see the bios is memory and graphics, and processor.  That way you can at least rule out all the other stuff first.
Todd H
  • Last login:February 17, 2024, 12:58:49 pm
  • It's Gameday!
« Reply #5 on: January 06, 2005, 10:06:59 am »
It almost sounds as if you have a blown capacitor on the motherboard.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #6 on: January 06, 2005, 01:08:02 pm »
Is the CPU fan hooked up?
If it's not, it will overheat within seconds and either the system will shutdown, or the system will lock up.
NO MORE!!
Beeeph
« Reply #7 on: January 06, 2005, 01:40:56 pm »
This forum is great and you guys are always a tremendous help!  Flipping out the CMOS battery seemed to have reset something and now it POSTs just fine.  Except now is giving a me a floppy disk error whereas it didn't before.  But I can figure that one out, thanks everyone!
Beeeph
« Reply #8 on: January 06, 2005, 02:29:41 pm »
The problem is back!  Popping out the CMOS battery worked about three times, now it wont POST and popping out the battery doesn't do a thing.  I hooked up the PC speaker and I'm not even getting any error beeeps.  Any other ideas, anyone?
Beeeph
« Reply #9 on: January 06, 2005, 03:18:46 pm »
now it's working again.  It looks like a wiring problem with the I-Pac was causing an error.  Great...a quirky cab.
