Main > Main Forum
CLEAR dust washers?
NoOne=NBA=:
How does that get you a moving dustwasher just under the graphics though?
RayB:
--- Quote from: NoOne=NBA= on December 30, 2004, 03:13:47 pm ---How does that get you a moving dustwasher just under the graphics though?
Most joysticks have a recessed top where the dust washer will fit, for below-the-panel setups. Do you understand?
NoOne=NBA=:
You know, you're right!
Hadn't ever occurred to me, since all my panels have been made from 1x.
The only other issue with the metal panels is that you'll have exposed screwheads.
Trimoor:
For the screwheads in metal panels, I suggest you get a threaded rod instead of bolts, and either epoxy or weld it to the bottom of the panel. No more screw heads.
missioncontrol:
--- Quote from: Trimoor on December 30, 2004, 05:58:45 pm ---For the screwheads in metal panels, I suggest you get a threaded rod instead of bolts, and either epoxy or weld it to the bottom of the panel.
