Author Topic: Mame is good for fixing arcade machines  (Read 5710 times)
SirPeale
  • Green Mountain Man
« on: December 29, 2004, 03:50:41 pm »
So I've had an NFL Blitz 2000 Gold board and drive for a while.  Drive is dead.
I'd been reading that you can use the CHD images to get yourself a 'fixed' drive, but I always thought that you needed a drive of the *exact* dimensions of the original.  So I never bothered.
Recently someone on RGVAC had posted they had fixed a hard drive game with one of the CHD images.  I asked about it, and they said they had just used an old drive.
So I looked on eBay, found a 6.4G drive (the size of the uncompressed CHD image) and it arrived over the weekend.  Uncompressed the image (which I had to do to an NTFS partition since the file size is > 4G)
So using a Linux installation that I booted from, the NTFS drive that I ripped the image to, and finally the 6.4G drive that the image would be written to, I did this:
dd blitz2k.raw /dev/hdc
It took roughly half an hour.  Of course, there's no progress indicator, so I pretty much just kept checking on it, seeing if it would error out (I tried this once before, and it did error out) and it was just sitting there.  Finally, it told me that the total number of bytes in equaled the total number out.
Took it downstairs, hooked it up, and crossed my fingers.  Sure enough, it started up!  I got my Blitz 2000 Gold motherboard a working drive, thanks to Mame and some info from the 'net.
I've heard a lot of arcade techs lauding Mame because the technical specs are so thorough.  Reburning dead ROMs from a set to give a dead board new life.  Following the specs in the Mame source itself to be able to trace the fault on an actual board.
I'm just grateful for the Mame devs, who made this whole thing possible!
Re: Mame is good for fixing arcade machines
« Reply #1 on: December 29, 2004, 03:56:47 pm »
Nice... very nice.   ;D
TOK
  • Last login:January 24, 2024, 05:14:24 pm
  • The Game Always Wins
« Reply #2 on: December 29, 2004, 04:04:39 pm »
Thats so cool. Also very true to the original idea behind MAME, which is often forgotten -to preserve these oldies so they're still around when the old hardware craps out.
Being able to play them is just an amazing fringe benefit!  ;D
RacerX
  • Last login:April 25, 2024, 04:53:33 pm
  • Longtime member, sometime poster.
« Reply #3 on: December 29, 2004, 04:23:28 pm »
Sweet!  Now I'll be keeping my eyes open for dead Blitz machines...
SirPeale
« Reply #4 on: December 29, 2004, 04:45:45 pm »
It wasn't a whole machine; it was a set I got from an arcade auction a couple years ago.  The arcade was closing, and sold all their merchandise.
GGKoul
  • Cheesecake Apprentice
« Reply #5 on: December 29, 2004, 04:52:44 pm »
So I can get a Blitz Board without a drive and attach my own drive to it??
SirPeale
« Reply #6 on: December 29, 2004, 05:20:12 pm »
Well...technically, yes.
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #7 on: December 29, 2004, 08:25:22 pm »
Peale, you said you picked up a drive of the same size?  Did you try it with a different-sized drive too, or did you just want to ensure the best possible chance with the least amount of risk?
I ask because you brought up the other size drive that someone claimed would work.
SirPeale
« Reply #8 on: December 29, 2004, 08:42:58 pm »
I tried it with a 40G drive at one point, but I think the drive itself was suspect.  The image itself is only 6.4G.  So I picked up a 6.4G drive off eBay.  It was a whopping $5.00, with another $5.00 to ship it.
iwillfearnoevil
  • Last login:February 13, 2010, 07:08:43 pm
« Reply #9 on: December 29, 2004, 09:59:01 pm »
if a bigger drive doesn't work, i wonder if it's partitioned to the smaller (correct?) size if it would work.
dabone
  • Last login:October 31, 2023, 12:03:37 pm
  • Time to work...
« Reply #10 on: December 29, 2004, 11:59:01 pm »
Alot of older machines cannot address a 40gb drive, they just freakout.
The bios on machines usually have a ide cut off depending on their age.
Common bios limitations.
504 meg
2 gb
4 gb
8 gb
30gb
and 137gb.
Real fun working with older machines now a days.
(And here's a good article on why there is a problem.)
http://web.inter.nl.net/hcc/J.Steunebrink/bioslim.htm
And the 30gb limit exists on a lot of p2 machines.
Later,
dabone
Gunstar Hero
  • Last login:September 28, 2014, 01:51:17 am
  • Back in action!
« Reply #11 on: December 30, 2004, 12:07:55 am »
Using MAME to fix real arcade machines is priceless. It really shows that the purpose of MAME is to preserve arcade life.   ;D
SirPeale
« Reply #12 on: December 30, 2004, 07:36:59 am »
No, for two reasons.  For the limitations mentioned below, I'm sure, and because you don't partition the disks.  You write the image directly to the drive.
Chris
    • Chris's MAME Cabinet
« Reply #13 on: December 30, 2004, 11:03:15 am »
504 meg
2 gb
4 gb
8 gb
30gb
and 137gb.
And, if you want to really dig into the wayback machine, 32 meg. :)
--Chris
dabone
  • Time to work...
« Reply #14 on: December 30, 2004, 12:01:29 pm »
Actually, 32 meg was a partition limitation, not a bios limitation.
(Computer bios didn't know about hard drives, it was up to the controller)
remember this?
debug
g=c800:5
or for the strange RLL controllers
g=c800:ccc
Later,
dabone
dweebs0r
  • Last login:December 16, 2023, 04:49:40 pm
  • Ascendo tuum!
    • Jodys Garage Arcade
« Reply #15 on: December 30, 2004, 12:41:08 pm »
Noob Question re: file system limitations:
Why did you have to use a NTFS partition because of the > 4 gig thing?
Couldnt you have used a newer Linux filesystem (Ext3 or ReiserFS)?
Is there some reason you had to use NTFS and could you do the whole thing within Linux with the NTFS writing abilities present in the latest kernel sources?
--Dweebs
DrewKaree
  • HAH! Nice one!
« Reply #16 on: December 30, 2004, 06:26:44 pm »
I'm guessing since he was decompressing the file, it was the required format the image was looking for.
Interesting to know all this stuff, though....all those dead HD games are starting to look more appealing!
SirPeale
« Reply #17 on: December 30, 2004, 06:33:04 pm »
No, it was a limitation in the filesystems.  I keep all my drives formatted in FAT32 so if I have to boot from a floppy in an emergency, I have access to those files.  Can't do that with NTFS that I know of.
I suppose I could have done it in either EXT2 or EXT3, but it was the easiest thing to do at the time.
JoeB
  • Last login:April 03, 2024, 11:38:08 pm
  • NES Fanatic
« Reply #18 on: December 30, 2004, 09:03:48 pm »
Actually, there are a lot of tools out there (including special linux distros) that allow you to boot and mount NTFS partitions and go as far as recovering lost admin passwords.   ;D
Arcadiac
  • Last login:April 14, 2020, 01:26:31 am
« Reply #19 on: December 30, 2004, 10:25:38 pm »
I got my first cab in trade from an operator for a set of Roms and CHD files. SSWWEETT!!  ;D
ARCADIAC!
payment_due
  • ---Probation---
  • Last login:August 19, 2012, 11:04:24 pm
  • ---Probation---
« Reply #20 on: January 26, 2005, 09:54:04 pm »
Would this work for Killer Instinct?
my MAMEcab progress blog: http://www.lealmedia.com/mame/
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
« Reply #21 on: January 27, 2005, 12:29:25 am »
i would assume so
"Owens is the ringleader in the ass hat circus"  D K
SirPeale
« Reply #22 on: January 27, 2005, 08:49:34 am »
Yes, but you have to use a special ROM.  There's a site somewhere that details this.  Do a Google search for 'killer instinct hard drive replacement'
