Author Topic: Warlords cabinet rebuild  (Read 2810 times)
KrawDaddy
  • Last login:February 19, 2007, 06:37:04 pm
  • I am a LOSER
« on: December 27, 2004, 04:18:43 pm »
Well I won it on EBAY but it has its problems.
Iam going to take detail measurements and post them (since NO current owners will) and I may also try to get some parts manufatured like legs and swivels.
Anyway there is monitor burn and ROM corruption. The game plays great but some of the wording is messed up (see pic). I hope someone can clue me in on what could be the possible problem and how to solve it.
« Last Edit: January 04, 2005, 09:21:59 pm by KrawDaddy »
All I ask is that my routers obey me as though they would the word of GOD!
Re: Warlords 4 player cocktail
« Reply #1 on: December 27, 2004, 04:22:08 pm »
Looks like you need new roms!  I don't know if those ROM chips are flashable or if you'll just have to replace the entire chips...
2600
« Reply #2 on: December 27, 2004, 05:16:57 pm »
I would first blow away any dust, dirt, or grime then clean and reset any removable chips.  Static is your enemy so make sure to follow some anti-static procedure.  If that doesn't work, I'd get some new roms programed.  I wouldn't unless I had to reprogram the other ones just in case something went wrong.
paigeoliver
  • Awesome face!
« Reply #3 on: December 27, 2004, 07:29:21 pm »
Krawdaddy. Now is the time to invest in an eprom reader/burner.
KrawDaddy
  • I am a LOSER
« Reply #4 on: December 27, 2004, 09:05:24 pm »
Do they make them for specific types of eproms?
How much do they cost?
Also is there a place that will burn chips for me?
Does anyone know of a good replacement monitor for a 14" Sanyo monitor?
Kind Regards\
Kraw
paigeoliver
  • Awesome face!
« Reply #5 on: December 27, 2004, 09:13:49 pm »
your monitor looks fine. Could use a cap kit though.
By the time you pay someone for a full set of Warlords eproms you could have almost bought your own eprom burner (they are only around $100 - $125). A newer eprom burner is going to support HUNDREDS of EPROMS including the ones on your warlords.
KrawDaddy
  • I am a LOSER
« Reply #6 on: December 27, 2004, 09:32:15 pm »
Do you believe this to be the problem with the graphics?
Also, are there tutorials for reading and burning these eproms.
paigeoliver
  • Awesome face!
« Reply #7 on: December 27, 2004, 09:44:43 pm »
The mame versions are almost ALWAYS the correct versions.
Does the game mess up the same way each time, or do the letters and numbers vary?
KrawDaddy
  • I am a LOSER
« Reply #8 on: December 27, 2004, 09:48:22 pm »
I dont know at this point.
paigeoliver
  • Awesome face!
« Reply #9 on: December 27, 2004, 10:24:28 pm »
Flash isn't the exact word.
Most arcade games use EPROMS. ERASABLE programmable, read only memory. Some only used PROMS (this is rare), which is just PROGRAMMABLE, Read only memory (without the eraseable part).
Basically it goes like this. Use the reader/burner to read each one of your chips and verify them with the ROMIDENT software. One will be bad. You don't have an eraser, so fork out the $3 for a new blank EPROM (or PROM) as needed and use the programmer to program it. Don't even bother buying an eraser unless you build up a stack of bad ones worth as much as an eraser costs.
KrawDaddy
  • I am a LOSER
« Reply #10 on: December 27, 2004, 10:39:19 pm »
Doesnt sound to hard
Does that burner integrate with a PC or does it have its own interface?
Also do you have a link to a vender?
Kind Regards\
Kraw
BTW is is possible to find a schematic for a warlords and find out what eproms I would need?  Maybe I could start there.
paigeoliver
  • Awesome face!
« Reply #11 on: December 27, 2004, 10:44:14 pm »
Kind Regards\
Kraw
They are USB now a days.
It takes a REAL WIZARD to be able to look at a game schematic and tell which EPROM is bad. Warlords just isn't common enough.
KrawDaddy
  • I am a LOSER
« Reply #12 on: December 28, 2004, 05:21:23 pm »
Well Ive just been infromed that the sound doesnt work.  Are sound problems generally minor or crippling?
Kraw
paigeoliver
  • Awesome face!
« Reply #13 on: December 28, 2004, 08:57:38 pm »
Usually minor. At this point I change my recommendation to first rebuild the AR2 board (with one of Bob Robert's kits), and if the sound doesn't come back then send the board out for repair. I am pretty sure elektronforge fixes that board type.
« Reply #14 on: December 29, 2004, 09:05:08 am »
Depending on the cost of shipping it there and back, plus the repair, it may be more effective to just give the broken one away to someone at that point and buy a working board.
Jakobud
  • Last login:May 05, 2024, 10:53:37 am
« Reply #15 on: January 01, 2005, 01:17:17 am »
Kraw, let us now when you get that Warlord's cabinet.  I'd like to get dimensions of it to post.
KrawDaddy
  • I am a LOSER
« Reply #16 on: January 03, 2005, 11:00:53 pm »
Anybody know what a the coin box looks like?  I need to replace it.
KrawDaddy
  • I am a LOSER
Re: Warlords cabinet rebuild
« Reply #17 on: January 04, 2005, 09:21:10 pm »
Well it looks like electronforge is going to service my PCB.  It looks like the bottom is falling out of the cab.
what I want to know is that I found all artwork except for the glass underlay.  I even found the serial number decal replacement.  Would it be wrong to completely rebuild the cabinet and transferall all hardware and componants to the new cab.  Would this be an outrage? One of the seven sins or would I be doing the cab a favor?  Iam going to beadblast all painted parts such as the legs and repaint with automotive paint.
Any opinions?
Kraw
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #18 on: January 04, 2005, 10:36:24 pm »
How bad is the cab?
Just refer to Vader88's re-build of a Missile Command. In the end he felt his scratch-built cab was too flawed to keep as is and he parted it out.
NO MORE!!
nostrebor
  • Not enough wit to effectively use this space...
  • Last login:October 04, 2013, 02:02:41 pm
  • SHOCKING!!
« Reply #19 on: January 05, 2005, 09:57:37 am »
I would think a re-build would be in order as long as the builder was willing to pay attention to detail and had some skill at woodworking. I think that you could easily meet those criteria, based on the Goldmine project.
I am in the process of "fixing" a stern upright and having just built a scratch cabinet I would say that the scratch cab was easier. It was also better constructed than this janky Stern. I could easily start this one from scratch, and make it exactly like the Stern built one. (Well, Paige could probably figure it out. ;))
cbmeeks
  • Last login:July 01, 2006, 09:29:58 pm
  • Metroid Classic
    • Metroid Classic
« Reply #20 on: January 05, 2005, 02:13:24 pm »
shouldn't this be moved to project announcements?  Looks like it is going to be a great project...keeps us posted
RETRO COMPUTERS!
A NEW place to chat about retro computers!
RETRO
METROID
Metroid Classic
DarkKobold
  • Last login:June 18, 2013, 11:31:23 pm
« Reply #21 on: January 05, 2005, 04:37:30 pm »
Kraw - Darn you, I was bidding against you on that Warlords... What did shipping end up costing? How did you get it shipped? Rhode Island is pretty far.
Also, that monitor roll is typical of warlords cocktails. Rod (Zinifer) from RGVAC did a wonderful restore on it.  Will show you how to fix the monitor and character problems. Best of luck.
http://www.kineplex.com/warlords.htm
Oh, and darn you again!  :'(
My games: Tapper, Asteroids, Cocktail-MAME, Tron, ROTJ, Tempest, Star Wars (not working)
My wants: Warlords Cocktail
KrawDaddy
  • I am a LOSER
« Reply #22 on: January 05, 2005, 10:15:11 pm »
Hey
A friend gave me a number for specialized transportation.
crashwg
« Reply #23 on: February 12, 2005, 01:02:30 am »
Any updates?  I'm dying for a set of acurate plans!
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
