Author Topic: Im new here Please Help  (Read 1983 times)
igotblueballz
  • Last login:December 27, 2004, 11:55:09 am
« on: December 22, 2004, 10:06:02 pm »
ok so im new here and im big into arcade games.. i got a time killers if you heard of it off ebay and the back door came smashed and when i turn the game on and start playing it blinks black and says system control Panel 1 ok then under that it says control panel 2 ok then it blinks and says system status ok... and it starts over... anyone know what i should do to keep the game from doing this please help !!!!
igotblueballz
Re: Im new here Please Help
« Reply #1 on: December 23, 2004, 01:03:36 am »
 :'(  someone please
paigeoliver
  • Last login:March 29, 2022, 06:10:15 pm
  • Awesome face!
« Reply #2 on: December 23, 2004, 06:50:45 am »
The power supply is probably adjusted wrong and your game is in a reset loop because of it. You need to get a multimeter and use it to check voltage and adjust that voltage to +5.1
igotblueballz
« Reply #3 on: December 23, 2004, 12:48:40 pm »
umm like i said im really new here can you give me any more detail into how i do that ??
pointdablame
  • Last login:November 09, 2023, 09:11:07 pm
« Reply #4 on: December 23, 2004, 12:52:04 pm »
you need a multimeter.  It's a tool that measures voltage.   If you test your power supply, you should be able to tell if there is a problem with it.  I believe it should have 5 and 12 volt rails????   Someone please correct me if I'm wrong... I'm not sure off hand.
But like paige said, that could very well be your problem.  There should be a dial or screw to adjust the voltage on the power supply if it is in fact not what it should be.
first off your and idiot
Goz
  • KOTA
  • Last login:September 03, 2020, 02:23:18 am
« Reply #5 on: December 23, 2004, 01:01:22 pm »
Some machines also have a dual position switch that can lock you into diagnostic mode. Honestly if I were you, I'd acquire a manual and try the multimeter and looks for common sense items such as shorts, wire harness unplugged, etc.
If it is a JAMMA cab, you usually have to go out of your way to go into diagnotics and the settings for the board.  I didn't see the game listed on KLOV and couldn't find a manual online for you, so really can't offer up additional advice.
Good Luck
-Goz
igotblueballz
« Reply #6 on: December 23, 2004, 01:12:20 pm »
do you know how i can get it to a menu or anything cuz when i turn it on it just go right to the game
igotblueballz
« Reply #7 on: December 23, 2004, 01:24:44 pm »
i just went behind it and i notied that a orange plug was unpluged... should i take a picture??
Goz
  • KOTA
« Reply #8 on: December 23, 2004, 01:33:07 pm »
If you take a picture and add it to the thread we can at least likely solve the mystery of the orange plug. Try to take a picture of the cab's inards as well as the plug and hopefully between seeing where it is coming from and the pliug we can at least try to help you with that.
Of course it would be best effort without having a schematic for the game.
-Goz
RayB
  • I'm not wearing pants! HA!
  • Last login:Today at 12:42:45 am
  • There's my post
    • RayB.com
« Reply #9 on: December 23, 2004, 02:51:50 pm »
I'd second the vote to check if there is a "test" switch turned on.
Next thing I'd do is buy a JAMMA game board of a game you like. Not only can you plug this new board in and see if it works, but you then can take the Time Killers and set it on fire. To this day I still feel offended that I wasted .50 cents on that piece of crap!
NO MORE!!
igotblueballz
« Reply #10 on: December 23, 2004, 02:57:39 pm »
where would i check to see if there is a test switch ??
pointdablame
« Reply #11 on: December 23, 2004, 03:37:55 pm »
My Xmen has a test switch in the coin door.  They can be anywhere I'd guess though.  Just look around the cabinet for a stray button.  Mine says "TEST" above it, yours may or may not.
Also... you said your back door was smashed... does it have a kill switch in the back?  I doubt this has anything to do with it since if it had a kill switch and it was not pressed down, the cab wouldn't start at all, but it might be worth checking for just to eliminate the chance.
igotblueballz
« Reply #12 on: December 25, 2004, 11:29:39 am »
merry xmas all sorry it took a few days but here are the pics please help !!!
http://www.mycampictures.com/timekillers/
Goz
  • KOTA
« Reply #13 on: December 25, 2004, 12:39:32 pm »
Time Killers is a JAMMA board. There have been a number of auctions for the PCB and it seems to go for about $30. So if you don't particularly care for the game or if the board is bad, you are not in bad shape. If you are not familiar with JAMMA it is a sort of std for how a PCD connects to monitor, power, and controls. This means that for the most part, you can get any other JAMMA board and just plus it it.
most of my JAMMA machines I access the test / diagnotics screens by shorting two pins at the JAMMA connector. I don't recall which two they were ( I installed a push button long ago on those) as I am visiting with family the next day or two  I can't easily look at the moment.
I also agree that it is a horible game. I would look for a game you do like. You can find classic boards converted to JAMMA, companies like CAPCOM, NEOGEO, etc make JAMMA boards. Depending on the type of game you do like, you could certainly find one that would be a direct replacement in your cab; should the board turn out to be wasted.
The wire thats not connected in the pictures looks to be a ground, but cannot be 100% sure.
-Goz
igotblueballz
« Reply #14 on: December 25, 2004, 12:50:13 pm »
lol sorry guys i love the game.... but i cant figure out why the game is saying that... and restarting and i cant find a test switch im... brand new like 3 game.. first time opening one
dabone
  • Last login:October 31, 2023, 12:03:37 pm
  • Time to work...
« Reply #15 on: December 25, 2004, 01:25:38 pm »
Try removing the board from the game, and reseating it, time killers if I remeber has 3 boards that interconnect to form the game.
Also, have you checked the voltage yet?
Get as copy of the jamma pinout here :: http://www.coin.demon.co.uk/jamma.htm
Get a digital multimeter.
(Cheap, just look at sears or your local hardware store)
Set it to measure dc, then connect the black lead to ground and the red lead to +5 on the jamma harness right by the board.
If it's low there is a small plastic screw on your power supply that you can turn to adjust the voltage.
The power supply is the small rectangle at the bottom of the case with a screw terminal strip labeled +5 +12 GND, etc.. etc..
DO NOT adjust it without a multimeter. You can take the +5 volts over 7 volts with that and damage your board.
And remember relax, it's just a arcade game, not rocket science.
Later,
dabone
igotblueballz
« Reply #16 on: December 25, 2004, 02:46:16 pm »
lol i dont got a voltage tester can you link me to a pic of what one looks like and ill pick one up tomorrow .. and i cant remove the board ive never opened one beofre this im not sure what im doing.... sorry but real newbie here tryin to learn please teach.... if your patience..
Goz
  • KOTA
« Reply #17 on: December 25, 2004, 03:14:30 pm »
Where are you located? Perhaps if a member is local to you, they may be willing to help.
-Goz
igotblueballz
« Reply #18 on: December 25, 2004, 03:43:48 pm »
WOW THAT WOULD BE GREAT... i live in the new haven area in connecticut and im willin to pay !!!
igotblueballz
« Reply #19 on: December 26, 2004, 09:25:54 pm »
anyone willing to help over the phone ??
igotblueballz
« Reply #20 on: December 26, 2004, 09:45:19 pm »
so when i turn it on and hold start it says system pass ok... red checksum bad good checksum good... and everything eles passed... anyone know maybe help over phone...
pointdablame
« Reply #21 on: December 27, 2004, 01:30:38 pm »
that "red checksum bad"  is an error I believe.  Is it not a memory/chip error?  Someone please correct me.
If I am thinking correctly, you may have a bad chip on the board, or at least a problem with one.
I'm sorry I'm not an expert on troubleshooting but I know that the checksum checks are looking for problems on the board, and the fact taht you have one is more than likely the problem.  Hopefully someone else here will be able to confirm this or add the correct info to it.
RayB
  • There's my post
    • RayB.com
« Reply #22 on: December 28, 2004, 11:59:16 am »
Just get a new tested board. I think I saw one on Ebay for $30 with manual. (Having the manual will help you figure out the errors on the first board too).
NO MORE!!
