Main > Main Forum
attaching tmolding to badly routed grooves
Pages: << < (2/4) > >>
The Jerk:
I'm having this issue in small spots.  I've got a glue gun that I havent even used yet.  Now I have a reason 2.
Also I think the fact that I havent used it yet is probably a good sign.
SirPeale:
I agree - glue gun.  Had a similar issue, worked a treat.
KrawDaddy:
use gorilla glue.  It exspands as it cures to completly fill your groove.  It is also easy to remove but holds well.  It is kicked off with a mist spray of water.  Then use a few clamps until it dries.
SirPeale:
--- Quote from: KrawDaddy on December 18, 2004, 10:11:25 am ---use gorilla glue.
paigeoliver:
In the past I have also just installed black t-molding and then nailed it in with some thin nails (and colored those black with a sharpie).
Go to full version
