Author Topic: Fear of Frying  (Read 1140 times)
mairsil
  • Last login:June 08, 2017, 11:48:20 pm
    • PouncingKitten Games
Fear of Frying
« on: December 14, 2004, 04:35:06 am »
If that title doesn't get attention, I don't know what will.
Anyway, in the next couple of weeks, I plan to completely replace the power and wiring portions of my converted Pit Fighter. Main reason is that some of the wiring is pretty ratty. It was converted into a Street Fighter Alpha 3 and I had to remove the kick harness because it actually had exposed wire in some places.
The second reason is that I am getting some interference in the monitor (typical ocean ripple). I think that it is being caused by the unshielded isolation transformer that is mounted right below the monitor in the PCB drawer. I am hoping that a shielded one will help the problem.
My main problem is that I don't want the machine to blow up when I am done with it and I don't want to fry while working on it. In particular, if the machine is completely unplugged, do I have to worry about live voltage being passed through the wiring to the monitor? I have no intention of grabbing the big red wire with one hand while licking a battery, standing in salt water and putting a penny in an electrical outlet with my other hand, but I want to be sure that I will be ok switching the RGB and sync wires.
Also, I plan to use a high quality computer power supply wired to a set of terminal blocks. I want to wire a matching molex connector to the terminal blocks so that I can unplug the terminal block and plug in a regular PC motherboard for easy MAMEing. I also need the extra 3.3V rail for my NAOMI board. Assuming that the line in goes to a standard AC distribution block before it gets to the PS, should there be any problems with this setup?
Any comments or help would be greatly appreciated.
Xbox 360 - Glide, Bingo Party, Poker Night
Flash - BunnyRun
Tiger-Heli
    • Tiger-Heli
Re: Fear of Frying
« Reply #1 on: December 14, 2004, 07:39:25 am »
No, but you have to worry about any of the charged capacitors discharging in an undesirable way.
