Author Topic: Bartop Plans  (Read 2408 times)
DarkSol
  • Last login:December 19, 2004, 12:48:21 pm
Bartop Plans
« on: December 13, 2004, 02:24:22 pm »
Does anyone know where I could find plans for a bartop machine?  I've been scouring the net for quite a while and all i see are upright, mini-upright, and cocktail plans.  This is actually going to be a JAMMA cabinet.  Anyone have any ideas?
Oddfeld
  • Last login:March 06, 2021, 07:04:15 am
  • I was Jeff Minter's llama!
Re: Bartop Plans
« Reply #1 on: December 13, 2004, 02:45:27 pm »
http://www.skum.org/bartop has plans for his Happy Hour cab
Also, check out this thread for some other examples:
http://forum.arcadecontrols.com/index.php/topic,27939.0.html
These guys don't sell plans, but do sell the empty boxes they use for their bartops ($200 for an empty MDF box though...):
http://www.extraordinaryarcade.com/arcademachines.html
Stingray
Re: Bartop Plans
« Reply #2 on: December 13, 2004, 03:05:02 pm »
If I were going to build one I'd buy an appropriatly sized monitor and just design the thing around it.
-S
missioncontrol
  • MC-Retro says Wot!
  • Trade Count: (+13)
  • Last login:May 23, 2021, 12:53:30 pm
Re: Bartop Plans
« Reply #3 on: December 13, 2004, 03:39:53 pm »
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
Re: Bartop Plans
« Reply #4 on: December 13, 2004, 05:58:37 pm »
I've got plans drawn up for a scaled down galaga/mspac style cab which I scaled from full size drawings from jakobud.com which are designed to house a 10" SVGA monitor.
These bartops which are approx 22" tall, 18" deep and 13" wide....cutoff just below control panel to look like a mini galaga cab.
These are just ink on paper at the moment, actually, ink and pencil on foam artboard that I am using as stencil to cut side pieces and note placement of top/back/bottom and control panel supports.
I was planning to create more detailed set of plans with pics once I get through my projects.
DarkSol
Re: Bartop Plans
« Reply #5 on: December 13, 2004, 09:50:37 pm »
-S
Well, thats why I'd want plans... so i can accomodate a 13" or a 19" monitor... but i do want it to be JAMMA rigged... this isn't going to be a MAME box
pointdablame
  • Last login:November 09, 2023, 09:11:07 pm
Re: Bartop Plans
« Reply #6 on: December 14, 2004, 12:20:05 am »
-S
You took his statement the wrong way.  What Stingray is suggesting [and I'm seconding] is that you find a monitor you want to use and base your cab on THAT monitor.  That's what I did with my bartop.  I had a monitor I wanted to use, and sketched up a design based on that monitor.  It's not difficult at all.  To be fair, my cab is a bit simple and bland looking... there are MUCH better looking bartops out there, but it gets the job done.
Get yourself a monitor, and you can whip something up really quick.
first off your and idiot
DarkSol
Re: Bartop Plans
« Reply #7 on: December 14, 2004, 10:49:21 am »
Well, I found a place that sells new monitors ($179 for a new 19").
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
Re: Bartop Plans
« Reply #8 on: December 14, 2004, 04:13:29 pm »
19" will make a pretty big bartop. If modern monitors require isolation transformers, you can figure it will be 24" deep, more or less, and a good 3' tall, by the time you get everything in it.
Bob
DarkSol
Re: Bartop Plans
« Reply #9 on: December 14, 2004, 10:54:11 pm »
Well, thats the smallest I can find... I'd REALLY like to find a 13"... but haven't found anything yet.
dabone
  • Last login:October 31, 2023, 12:03:37 pm
  • Time to work...
Re: Bartop Plans
« Reply #10 on: December 14, 2004, 11:17:50 pm »
I just got a couple of 9" VGA gray scale monitors.
Anybody wanna build a bartop b/w classics game?
I only want to keep one around for a test monitor.
I'll give the monitor to anyone that wants it for the shipping from 37421.
(And thats shipping only, none of that handling crap)
Later,
dabone
SteveJ34
  • Trade Count: (+9)
Re: Bartop Plans
« Reply #11 on: December 14, 2004, 11:55:20 pm »
13",14", and 15" are easy to find....especially if you don't need something new....what area are you located in?
IG-88
  • Last login:May 09, 2023, 08:29:46 am
Re: Bartop Plans
« Reply #12 on: December 15, 2004, 04:53:18 pm »
Later,
dabone
Hey Dabone, check your PM. I may want that 9" monitor.
-HarumaN
Xphile
  • Last login:July 03, 2010, 12:54:48 am
  • I'll never go back to the NHL!
Re: Bartop Plans
« Reply #13 on: December 16, 2004, 01:49:29 am »
he wants an arcade monitor (CGA) not a VGA or SVGA Computer monitor..
(It's a Jamma bartop.. ;) )
Pull a year and a half strike- it's over 4eva..
besides, WHL rocks!
SteveJ34
  • Trade Count: (+9)
Re: Bartop Plans
« Reply #14 on: December 16, 2004, 09:29:48 am »
You are correct...my bad.
Maybe Drew can slap me again so I'll pay attention better.
DarkSol
Re: Bartop Plans
« Reply #15 on: December 17, 2004, 12:54:04 am »
S'alright... I'll figure something out.  I know it's not going to be technically a bartop, but i dont really want a mini-cab or a full size thing either... so ill probably just modify some plans, I guess
