Author Topic: Mounting Glass over Bezel  (Read 1036 times)
eyal8r
  • Last login:May 11, 2007, 01:14:20 am
« on: December 09, 2004, 11:18:07 pm »
Hey guys-
Been looking through everyone's cab pics- but one thing I dont see is how you guys have mounted the glass/plexi over the bezel?  I don't see any mounting blocks or whatnot on the outside- what am I missing?
thanks
D
Will
  • Last login:April 08, 2012, 03:32:27 am
  • Finished Lurking.....
Re: Mounting Glass over Bezel
« Reply #1 on: December 09, 2004, 11:47:26 pm »
Well I can only speak for my cab but it came with a metal bracket (clip)that screws into cabinet and keeps the glass from sliding out.
somunny
  • Last login:September 05, 2018, 02:22:25 pm
  • Is it hot in here?
« Reply #2 on: December 09, 2004, 11:54:22 pm »
Depending on your cabinet, you may just be able to let it rest against the bezel and let the weight of the glass hold it in place.
Coop
eyal8r
« Reply #3 on: December 10, 2004, 03:23:10 am »
ahhh yes- those little glass clips. That's what I'll use.  Thanks!
D
coasternuts
  • Last login:January 11, 2010, 08:39:24 pm
  • Ouuuuch....I am not the worst game ever!!
« Reply #4 on: December 10, 2004, 07:51:20 am »
Anyone have a link or picture of one of these metal glass clips?
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
« Reply #5 on: December 10, 2004, 09:02:03 am »
Another approach some have taken for custom built cabs is to route a slot at the top which is usually the speaker shelf under the marquee and a similar slot in the bottom ledge.
You make the slot slightly deeper in the top and cut the glass or plexi height in such a way so that when fitting into place you can lift it up into the top slot then set it in place in the lower slot.
I didn't have the forethought when constructing mine to plan for this need so was going to just add a small frame around it or a piece at the top and bottom. However, my cab doesn't move around so I once I set it in place, I never added anything to hold it there, it's own weight and tight fit does that just fine.
ras2a
  • Last login:November 19, 2016, 02:21:26 pm
  • I drink, therefore I am!
    • Nolij
« Reply #6 on: December 10, 2004, 10:12:08 am »
Coop
precisely what I'm planning to do.  The angle and weight of the glass should be such, that no 'retaining' method is required to secure the bezel in place.
Craig
somunny
« Reply #7 on: December 10, 2004, 11:08:17 am »
I suppose it all depends on how 'agressively' you play.  ;)
Coop
Hoagie_one
  • Um....whats a cabinet
« Reply #8 on: December 10, 2004, 11:12:14 am »
the angle on my cab is such that i only have a clip on the bottom and rubber on teh 4 corners for padding and no slip action
Chris
    • Chris's MAME Cabinet
« Reply #9 on: December 10, 2004, 02:45:20 pm »
On my cab, which is originally a Super Contra cab, the class slides behind the speaker panel and at the bottom is wedged in place by the control panel.
--Chris
