Main > Main Forum
Anyone have any ideas on how to make easily Interchangable metal CP's?
Stingray:
--- Quote from: Minwah on December 09, 2004, 04:36:55 pm ---I use similar clamps to Stingray, but I have a large front door which is easier for me to use for access than the coin door.
Mine has the wide Midway coin door, so it's actually not a problem accessing the clamps through it. Plenty of room. I could see how it might be difficult if you had a smaller coin door, especially if it were offset to one side like the coin door in the cab you pictured.
-S
NIVO:
i too am using thumbscrews hoagie. 5 to be exact. All i did was use threaded inserts into the wood behind the control panel(and like said above, all panels will have the same size). Works well so far.
Hoagie_one:
got any pics of that for reference?
Minwah:
--- Quote from: Stingray on December 10, 2004, 09:38:37 am ---Mine has the wide Midway coin door, so it's actually not a problem accessing the clamps through it. Plenty of room. I could see how it might be difficult if you had a smaller coin door, especially if it were offset to one side like the coin door in the cab you pictured.
Exactly...my door is quite small and as you say the offset doesn't help!
NIVO:
ok hoagie, here are pics of the insert in the wood, and the 2nd pic shows the actual part #, I picked these up at menards, but you could probably get them elsewhere as well
last pic shows my panel, notice the 5 small holes(1 on either corner up top, 3 across the bottom) pc thumb screws are a perfect fit. Will take about 15 seconds to change a panel. About as simple as you can get and works really really well.
