Main > Everything Else
How do i get data off of a broken hard drive?
Hoagie_one:
removing the platers is next to impossible without destroying the hard drive.
ntjedi:
--- Quote from: Hoagie_one on December 08, 2004, 04:44:12 pm ---removing the platers is next to impossible without destroying the hard drive.
oh, come on, I saw it on CSI a couple of weeks ago! ;D ;D
Hoagie_one:
my bad....must be easy then.
PacManFan:
You don't need to replace the platters, replace the control electronics instead. More than likely, the platters are fine, but you hosed the electronics with static, so just swap out the control circuitry.
Hope this helps. If it's an older drive, you can probably ebay for it by part number. What is it?
-PMF
Sephroth57:
it is a maxtor 80GB, heres what it says on the label
Code: YAR41BW0
SN: Y2Q3WVGE
6YO8OPO422211
