Main > Main Forum
casino-type-wheel
postkassen:
oh, ill have to check it out, thanks! i was only thinking of having ten songs on the wheel anyway.
the origin of this project was a "drink'o'matic" machine some friends made, where you spun a wheel and the machine automatically made the drink the wheel stopped on. was really a quite cool machine, it held six or seven types of liqueour, and a couple of sodas. the machine wasnt properly made though, so it broke down after a few weeks use, and they have since abandoned the wheel-function of it for just buttons, but then we figured out we had to use the wheel for something:)
so im heading down to check out how they made the wheel function tomorrow, hopefully there was a genious solution to it:P
Chris:
--- Quote from: postkassen on December 08, 2004, 11:40:44 pm ---so im heading down to check out how they made the wheel function tomorrow, hopefully there was a genious solution to it:P
Maybe not, if it broke... :)
Most of the problems I see with home-made wheels is people just put a bolt through the wheel as an axle. You'll need a good bearing in the middle to hold up to all that spinning.
I need to tinker with the input for DOSCab/WinCab Jukebox anyway, so the next version will support up to either 26 or 36 single-key inputs.
--Chris
postkassen:
oh the wheel didnt break, the electronics of the drinkmixer werent protected properly, so they got wet and died:P
rdagger:
--- Quote from: postkassen on December 08, 2004, 11:40:44 pm ---the origin of this project was a "drink'o'matic" machine some friends made, where you spun a wheel and the machine automatically made the drink the wheel stopped on.
I wonder if I could add a drink'o'matic to my cab.
postkassen:
argh, i checked the wheel out, and they had cheated and gone the easy way. you can spin the wheel, but you have to push a button after the wheel stops. that way you only get one signal to the computer. but i want to make it so when the wheel stops, in automagically sends the corresponding signal to the computer...
