Main > Everything Else
Software Problems: Wife1.0
Pages: << < (4/6) > >>
danny_galaga:
girlfriend and wife suffix's are incorrectly marked. darkcolbald is almost right. girlfriend suffix's continue upward infinitely. The last version i had was v18.0. it is the very ACT of marrying that automatically nulifies all previous suffix's and reverts to 1.0. a bit like Pol Pots year zero. And NEARLY as terrifying i hear...
i'm aiming for v100 before i reach 40 . variety is the spice of life  ;D
geomartin:
Attention Girfriend 7.0 users:
Once Girlfriend 7.0 has exceeded it's one year trial period it will attempt automatic upgrade to Wife 1.0 everytime you are connected online.  To avoid this problem we recommend a fresh install of Girlfriend 7.0 every 10 months.
Pacific Ripper:
Some applications can be used to optimize systems like Alcohol 1.2b ( may affect memory). Erectile_Pill 1.0 is used to optimize plug-and play for older systems although nowadays it is being used on new healthy systems. You can always try warez like Crack 1.0 but depending on Wife 1.0's operating environment, it can crash the system irrevocably and also can cause the sytem to be busy and unstable for no apparent reason.
Daniel270:
A Must Have for those using Girlfriend 7.x and up...
Be sure to buy and use Condom 3.0 on all your Plug and Play applications or you'll discover that Baby 1.0 has been accidentally installed...
Gunstar Hero:
Hmmmm, this all sounds very interesting.  :)
Is there a wrapper so I can set it up with MAMEwah?  ;)
Go to full version
