Author Topic: El cheapo Hole Saw Kits?  (Read 922 times)
brained
  • Last login:February 02, 2023, 08:54:08 am
  • Raised by Atari
    • Nux
« on: December 03, 2004, 09:17:53 am »
has anyone used those cheap hole saw kitS?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=42937&item=3856191091&rd=1
I'm wondering if they' are good enough for cutting a metal CP?
JustMichael
  • Mmmmm!! Cheesecake!!
Re: El cheapo Hole Saw Kits?
« Reply #1 on: December 03, 2004, 09:21:19 am »
I would email the seller and ask but usually if it doesn't say it can cut metal then it doesn't.
mcdo15
  • Last login:February 16, 2008, 01:49:17 pm
  • why can't i make up my mind
« Reply #2 on: December 03, 2004, 09:24:05 am »
yeah..u need a different bit... if you go to home depot, they are in tools section..i brought a wood one for about 10-15 bucks...
Hoagie_one
  • Um....whats a cabinet
« Reply #3 on: December 03, 2004, 09:51:41 am »
i bought a greenlee hole punch.
it was the smartest thing i ever did.  Makes perfect holes in metal and nothing other than a socket wrench is requred to use it...well you need a drill to make a starter hole.
Hoagie_one
« Reply #4 on: December 03, 2004, 09:54:37 am »
crashwg
« Reply #5 on: December 03, 2004, 12:39:21 pm »
I have a feeling Brained isn't cutting button holes.  The smallest hole saw in that set is 2.5"...
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
brained
  • Raised by Atari
    • Nux
« Reply #6 on: December 03, 2004, 12:44:59 pm »
I'm cutting holes, but I just took one of them hole saw kit. But this seems to work..
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=20797&item=4340064634&rd=1
It says it cuts sheet metal, but I dunno... A greenlee is way too expensive :S and I would still need a 3" one for my trackball  ???
fredster
  • It's all good!
« Reply #7 on: December 03, 2004, 02:28:00 pm »
If you just want one punched, you can take it a machine shop or a welding shop nearby.
They can do one hole for you for cheap.  You can have them punch it out with their greenlee punches.
You might be surprised how cheap it is to do that, especially if you take the plate and mark it up with a sketch.
After all, you are only making one.
Stingray
« Reply #8 on: December 03, 2004, 02:50:24 pm »
I've got a few super cheap hole saws that I bought in a discount bin at a hardware store once. Utter crap. They can't even cut softwood. The only thing they're good for is plastic.
-S
brained
  • Raised by Atari
    • Nux
« Reply #9 on: December 03, 2004, 05:15:33 pm »
I'm going for the metal shop thing. I've already drilled pilots holes for the buttons, joystick and trackball... so what the heck
