Main > Everything Else
Computer Cooling Help
menace:
I got a buddy to build the water block using 1/8" copper soldered into a block with fittings soldered on. The pump will be a submersible aquarium pump and the tank is one of those small hexagon ones that i picked up at a yard sale--with the pump submersible and the water reservoir sealed there is no need for a radiator unless you are overclocking--the volume of water required to submerse the pump is enough to dissipate the heat--it will go up a degree or two but you can negate that with more water.
danny_galaga:
--- Quote from: DrewKaree on November 30, 2004, 11:38:13 pm ---He didn't use a radiator.
DrewKaree:
Why take the coffee out? Hot water going in, liquid going out....it's a watercooler/coffee maker, brought to you by the redneck version of the sharper image - The Dull Picture ;)
