Main > Everything Else
X-Arcade Cancelled my Auction!!
paigeoliver:
Exactly. Using automated software to cancel people's auctions is immoral. Thus I no longer respect X-Gaming's trademark terms. What if someone sold an ex-gaming establishent (in the real estate section). Or what if they were indeed selling their x-arcade. Or what if their was an adult movie called sex-arcade?
The image trick is your friend. I have seen some sellers who make their entire auction an image. It foils automatic search and destroy things quite well.
--- Quote from: maraxle on November 29, 2004, 10:44:09 pm ---
--- Quote from: zaphod on November 29, 2004, 08:55:04 pm ---Happened to me a couple months back, too. Used 'X-arcade' in the text of my ad. I emailed X-gaming about this. Shawn emailed me back within ten minutes with a very polite explanation. The applicable (to your situation) paragraph from his reply:
"Actually, we automate the process on ebay's vero program to object to any
auctions which list any of our trademarks. (for trademark and also for
search manipulation)."
Basically if you use the term X-arcade or X-gaming in your copy, you'll probably get flagged. They don't even see the ads; a program catches them.
On the plus side, you should get reimbursed by ebay for the auction. Just remove the comparison and relist. You'll be fine.
What if you're trying to resell your X-arcade joystick you no longer need?
rchadd:
--- Quote from: paigeoliver on November 29, 2004, 10:53:47 pm ---what if there was an adult movie called sex-arcade?
the mind boggles over what that might contain....
starring Ms Pacman with Super Mario
also featuring Donkey Kong
fredster:
Who stars in that Sex Arcade Movie?
Jane Fonda?
Tiger-Heli:
--- Quote from: paigeoliver on November 29, 2004, 09:31:03 pm ---Relist your auction and instead of using the text of your description put that exact text into an jpeg file and show it that way. Won't get flagged because you can't search for text in an image file, at least not on ebay.
Other ideas - This controller uses actual Happ controls and is less expensive than the commercially available product with the black chinese knock-off joysticks and buttons and the big white X on top, which is available at Fry's or online.
Their search engine won't find that either, but Fry's might >:(
paigeoliver:
Are people actually really searching for X-Arcades anywhere? The stupid company spends so much money on adverts and search engine manipulation that you don't even need to search for it, ever.
