Author Topic: 1/2" or 3/4" CP?  (Read 1210 times)
eyal8r
  • Last login:May 11, 2007, 01:14:20 am
1/2" or 3/4" CP?
« on: November 29, 2004, 02:43:20 am »
Hey guys-
I have a 1/2" CP top right now- am about to order my joysticks and buttons and whatnot. Do I need a 3/4" top for this, or will it be ok with just 1/2"?
I am installing 8ways, buttons, spinner, trackball....
D
Apollo
    • Eight Bells
Re: 1/2" or 3/4" CP?
« Reply #1 on: November 29, 2004, 03:07:20 am »
Firstly what is your CP made out of? Secondly it should be fine, in fact better tan 3/4 as you will get better height out of your joysticks.
eyal8r
« Reply #2 on: November 29, 2004, 03:19:31 am »
ahhh- its out of MDF... the rest of the cab and CP is 3/4", I just did the top in 1/2" cuz I thought I might not have to route out to fit the controls... is this true?
D
paigeoliver
  • Awesome face!
« Reply #3 on: November 29, 2004, 04:50:25 am »
I always use 3/4" and never route out anything. Joysticks are usually designed for either 3/4" wooden panels, or teeny thin metal panels.
Routing out under wood panels is sure popular here, but I haven't seen it MUCH on real games, have seen a few, but they are the exceptions, not the rules.
captainpotato
  • Last login:November 11, 2016, 06:10:59 am
  • I'm a tapir!
    • Tapir Design
« Reply #4 on: November 29, 2004, 08:24:01 am »
It depends on the joystick you are using. I found that I had to route out my CP from underneath for a J-Stik - if I didn't, it sat way too low with 3/4" plywood. I gather that other joysticks have longer shafts so this may not be a problem with them.
paigeoliver
  • Awesome face!
« Reply #5 on: November 29, 2004, 08:37:24 am »
Thats because the j-stick was designed for metal panels, not wooden panels.
If you use the correct joysticks for the correct applications then you don't have to route anything.
« Reply #6 on: November 29, 2004, 08:48:40 am »
Burrrrrrn!  :police:
captainpotato
  • I'm a tapir!
    • Tapir Design
« Reply #7 on: November 29, 2004, 09:56:45 am »
[Thats because the j-stick was designed for metal panels, not wooden panels.
Perhaps, but as routing out a few mm is no work at all, I'd much prefer to do that than to get a joystick that wasn't *exactly* what I wanted...
Tiger-Heli
    • Tiger-Heli
« Reply #8 on: November 29, 2004, 10:11:48 am »
Agreed, another point is if you are going to add Lexan (plexiglass, etc.) to your CP, that will add about another 1/8" so you will effectively be at 5/8-inch. . .
eyal8r
« Reply #9 on: November 29, 2004, 11:54:16 am »
Right- should've mentioned that. I DO plan on adding plexi.  Also, I am using Ultimarc's T-Stick Plus and their E-Stick, as well as a spinner and TB (not sure which ones yet).
So, with this info, am I ok, or, do I need to recut the CP top?
D
JCKnife
  • Last login:November 04, 2008, 09:41:57 pm
« Reply #10 on: November 29, 2004, 01:20:29 pm »
I'm also curious of MDF is preferable for a CP top, or plywood?
(sorry for the threadjack but I think it's on-topic).
