Main > Main Forum
SlikStik *Joystick Poll*
Pages: << < (2/2)
Minwah:
--- Quote from: Sasquatch! on November 24, 2004, 11:19:14 pm ---So what are your "new 2-piece ball top joysticks for 49-way joystick bases" anyway?  I don't know what you're talking about, mang.
See this: http://forum.arcadecontrols.com/index.php/topic,27968.0.html
I went for 49-way, as it is the only type from the list I own, and also the others are available with balltops already (not the anodized one's I know!).
Kremmit:
I'll just echo NoOne=NBA=, I'd really like to see these for Wico bases.  They oughtta be in the poll.
On the other hand, hy is the 49 way in the poll when you say you've already committed to do it?  ???
And while we're at it, according to Paigeoliver, you can already fit a Happ Super handle to a Ms. Pac reunion base:
http://forum.arcadecontrols.com/index.php/topic,27429.0.html
So you don't have to worry about that one, either.
I remember seeing this:
http://forum.arcadecontrols.com/index.php/topic,6294.msg44224.html#msg44224
which basically says you can put a Wico handle on a P360.  I posted in the other thread about the possibllity of swapping the other way, which is to say put a 360 handle on a Wico base.  Now I see Patrickl's comments, so that looks likely, too.
So go for the T-sticks!
SlikStik Christian:
Kremmit,
Kremmit:
--- Quote from: SlikStik Christian on November 25, 2004, 05:11:17 pm ---Someone send me a Wico joystick (I already have the Ms. Pac reunion in the shop somewhere) and I will spec out all 3 and see what will fit with what and what won
shmokes:
I don't just want it to "fit" my Ms. Pacman reunion joystick.  It needs to fit it proper.  A stick made to fit into that joystick base should have a short shaft just like the original.
Pages: << < (2/2)
Go to full version
