Author Topic: Problems With Control Buttons  (Read 835 times)
kommando2004
  • Last login:November 22, 2004, 10:20:37 pm
« on: November 20, 2004, 06:11:28 pm »
I am having problems with my MAME arcade machine
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
Re:Problems With Control Buttons
« Reply #1 on: November 20, 2004, 08:23:08 pm »
We need more info. Follow the wires from the buttons and tell us what they connect to.
Bob
Apollo
    • Eight Bells
« Reply #2 on: November 21, 2004, 12:08:04 am »
I thought MAME didn't support buttons 5 & 6. Don't you have to map these seperately?
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
« Reply #3 on: November 21, 2004, 12:11:41 am »
Maybe in some long forgoten version, but ever since I've been using mame, whihc is since .63ish it has had all the buttons needed for each player
Hiub1
  • Last login:June 05, 2011, 11:43:25 am
  • www.sleepyjack.com
« Reply #4 on: November 21, 2004, 12:42:49 am »
The quick connects might look like they are OK, but they are most likely not making good contact. If you can, go ahead and recrimp the connections if that is you do have quick connects,
kommando2004
« Reply #5 on: November 21, 2004, 01:15:23 am »
Thank you for all the replies. I just disconnect the two wires behind one of the good buttons and reconnected on to the one that wasn
ddockery
  • Last login:October 29, 2005, 11:51:14 am
« Reply #6 on: November 21, 2004, 01:16:53 am »
To remap, while inside MAME, press the TAB key.  From there it should be pretty straightforward.
Tiger-Heli
    • Tiger-Heli
« Reply #7 on: November 22, 2004, 07:51:49 am »
Mame does not initially support buttons 5 and up for Player 2.  Player 1 should be working, and Player 2 should work after configuring in the TAB menu.
paigeoliver
  • Awesome face!
Re: Problems With Control Buttons
« Reply #8 on: November 22, 2004, 08:12:09 am »
Fire up NOTEPAD and press those buttons and see if they are sending any keys.
They probably aren't mapped.
Or, your cabinet might have a JPAC in it, and the builder didn't bother to do the extra wiring for buttons 5 and six.
kommando2004
« Reply #9 on: November 22, 2004, 11:35:46 am »
I press tab and went into the Input General, and selected player1 button the 5 and 6 button pressed enter on my keyboard, then I started to press the buttons themselves on the control panel, there is no response registering on the screen. How do I get into notepad, I will need to hook up the computer to a PC monitor first, because the window 98 screen on my cabinet is spilt and warped. Thank you again all for your helpful responses.
kommando2004
« Reply #10 on: November 22, 2004, 10:20:19 pm »
My cabinet does have a Ultimarc J-Pac, what does that mean? Thanks
paigeoliver
  • Awesome face!
« Reply #11 on: November 23, 2004, 07:04:17 am »
That means that buttons 5 and six probably aren't wired at all, even if you do see wires.
Ok, I am going to assume you are smart enough to figure out which wire is ground. Good, ignore THAT and follow the other wire off the buttons back, you will probably find that it leads nowhere. It needs to be hooked up to a screw terminal on the JPAC. The J-Pac screw terminals are labeled, which should make it easy.
The JPAC only supports 4 buttons per player through the edge connector, the other ones hook up via the screw terminals. I have the J-Pac as well and had to do the same thing.
