Main > Everything Else
DVD copying forum?
pointdablame:
ok why on earth would you tell him about thousand dollar duplicators???? that's insane.
http://doom9.net/
http://www.afterdawn.com
All the info you need is there. You do NOT need a dulpicator, not unless you plan on making 500 copies of each disc. Basically, you need at the very least a dvd burner, some blank dvds, and a program called DVD Shrink. You'll probably want to get a seperate burning program and a few other specialty programs, etc etc.
Once you get the hang of it, it pretty much is... put in original, blank and hit a few buttons. Very simple.
HaRuMaN:
And don't forget the all important DVD Decryptor... a must have, as well as DVD shrink. I use these two, along with Nero, to copy DVD's.
Trenchbroom:
--- Quote from: HarumaN on November 17, 2004, 08:52:06 pm ---And don't forget the all important DVD Decryptor... a must have, as well as DVD shrink. I use these two, along with Nero, to copy DVD's.
These two programs are all you need. Google them and copying DVD's will be easier than managing MAME roms in no time.
namzep:
Also, you may want to grab a copy of Alcohol 120, especially if you're using DVD Shrink (then you can check the quality of the rip you made).
1UP:
www.videohelp.com
Everything you need is there, for any type of copying or authoring you want to do.
