Software Support > SK Jukebox
Yet Another Jukebox Program
JLR2000:
Thanks SK for another great Update!
Regarding the SS - I noticed that if you set the time for the SS to engage that is the time interval in between scrolls. The other time slider below doesn't really affect the time interval between scrolls. Not a big deal, but I thought I'd let you know.
Thanks so much for adding this Feature!! One question/request is on the Options dialog when you input the SS time interval is it possible to have a number input box with the slider? On the slider I can only get it to hit 1, 14, 28, etc.... I thought if there was an input box where the number moved I could manually type in "10" or "25". Just a thought, totally not necessary but if it's easy to do and you think it's worthwile....
Thanks again for your efforts!
SalmonKing:
--- Quote from: JLR2000 on October 24, 2005, 02:09:18 pm ---Thanks SK for another great Update!
The top slider is supposed to be the time before it starts scrolling, the bottom slider is to then scroll it every x seconds after that. So, not sure what's going on there.....I set the top slider to 30, the bottom slider to 6, and after 30 seconds it scrolled.....6 seconds after that, it scrolled, 6 seconds after....etc
As for getting the slider right, just click on the slider & get it close to where you want it. You can then use the left & right arrows to tweak it. ;)
SalmonKing:
--- Quote from: bauhaus on October 24, 2005, 01:19:43 am ---Hi Sk
Some focus problem with this function don't click with your mouse ...or ctrl+alt+suppr :)
Actually, I think I know what you mean by this now....if the albums are auto scrolling, and you click away from the program to another application (without moving your mouse over the main screen), it will then do the next scroll after bringing the program back to the front.
If that's what you mean, I just fixed that. :)
JLR2000:
--- Quote from: SalmonKing on October 24, 2005, 04:52:55 pm ---
Hmmm, I just tried again and I get the same results as earlier reported. The top slider controls the time before it starts scrolling AND the amount of seconds between scrolls. The bottom does nothing. Here's the test I did:
Top slider: I clicked and attempted to move with left & right arrows, but it did not move. I set to 28 seconds using mouse pointer.
Bottom Slider: I clicked and attempted to move with left & right arrows. The slider DID move here and I set to 6 seconds. Clicked Save.
SK Jukebox started and after 28 seconds the scroll began, 28 seconds later it scrolled again, 28 seconds later again.....
I'm running XP SP2 with latest updates. I did just reload the update files from the zip I downloaded last night. If it's just me I will save my .ini file, remove/uninstall all and do a fresh install and try it again. Let me know if it's just me.
Thanks again!
PileDriver:
Same here. The bottom bar dosen't seem to do anything.
I set the top to 30sec and the bottom to 5.It starts after 30sec and then every 30sec after it scrolls.
Pile
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
