Author Topic: Powder coated control panels?  (Read 877 times)
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« on: November 16, 2004, 10:56:18 am »
I have seen this talked about before and I was wondering exactly how this was done.  Is there some special type of paint that is used to do this or is it more of a process?
Hoagie_one
  • Um....whats a cabinet
ras2a
  • Last login:November 19, 2016, 02:21:26 pm
  • I drink, therefore I am!
    • Nolij
Re:Powder coated control panels?
« Reply #2 on: November 16, 2004, 11:01:23 am »
Poweder coating is precisely that.  A special gun/applicator is used to coat the material in a fine powder.  this is then placed in a sort of oven where it is baked and the powder cures.  Typical finish is VERY VERY durable and usually very shiney too.  Although I would imagine you can get 'matt' finishes as you can with paint
edit: good link - hoagie
« Last Edit: November 16, 2004, 11:03:13 am by ras2a »
Hoagie_one
« Reply #3 on: November 16, 2004, 11:03:00 am »
they do have faux powder coating spray paints, that have a good textured surface....not the same though.
quarterback
  • Last login:August 16, 2023, 10:51:41 pm
« Reply #4 on: November 16, 2004, 11:49:52 am »
Powder coating equipment is available at Harbor Freight.
Here's a $60 "Powder Coating System" and if you put "powder coat" in the search box, you'll come up with all kinds of stuff including an oven
-- Chad Tower
Popcorrin
« Reply #5 on: November 16, 2004, 11:56:17 am »
Thanks for the quick responses. ;)
daywane
  • Last login:Today at 05:15:43 pm
  • GRRRR!
« Reply #6 on: November 16, 2004, 06:01:45 pm »
example of powder coat.
your brake lines and power steering lines are powder coated
at least all the paerts we make at my work is.
