Author Topic: 4 way tip.  (Read 1374 times)
paigeoliver
  • Awesome face!
4 way tip.
« on: November 13, 2004, 11:46:28 am »
If you have a Happ super and a Ms. Pac-Man reunion stick you can just swap the handles to either get a shorty balltop 8-way or a true 4-way with a long bat top.
I just tried it, it works fine. I might swap out my Wico for one of these just to match my other 2 sticks.
paigeoliver
  • Awesome face!
Re:4 way tip.
« Reply #1 on: November 13, 2004, 11:52:02 am »
Edit. It only works one way, You can make the bat top 4-way, but you can't make the ball top 8-way, it doesn't work no matter how you swap parts around.
subzero23
  • Last login:April 24, 2017, 03:21:43 am
Re:4 way tip.
« Reply #2 on: November 13, 2004, 12:03:46 pm »
What is the maximum thickness you can install a Ms. Pac-Man reunion joystick?
I was thinking about routing to 1/8" (or thicker if possible) + the 1/8" plexiglass = 1/4"
This user has been banned by saint and cannot reply. --- saint
paigeoliver
  • Awesome face!
Re:4 way tip.
« Reply #3 on: November 13, 2004, 12:27:01 pm »
Maximum thickness is METAL. And you won't want to use plexi with one of these either. The shaft is incredibly super short.
subzero23
Re:4 way tip.
« Reply #4 on: November 13, 2004, 12:40:07 pm »
What thickness metal then?
spiffyshoes
  • Last login:September 20, 2015, 01:24:46 pm
Re:4 way tip.
« Reply #5 on: November 13, 2004, 12:49:36 pm »
If you were using the longer handle from the Super would you be able to bottom mount the PacMan stick?
paigeoliver
  • Awesome face!
Re:4 way tip.
« Reply #6 on: November 13, 2004, 12:51:33 pm »
If you use a super handle you can mount it normally in a wood panel. A Reunion stick is essentially a true 4-way super with a different handle. That is why you can swap the handle.
quarterback
  • Last login:August 16, 2023, 10:51:41 pm
Re:4 way tip.
« Reply #7 on: November 20, 2004, 06:27:10 pm »
Does this last sentence mean that I could use a Wico leaf balltop in place of the short Ms. Pac reunion stick (to get a more reasonable height through a wood cp)?
-- Chad Tower
paigeoliver
  • Awesome face!
Re:4 way tip.
« Reply #8 on: November 20, 2004, 07:05:51 pm »
No, Wico handles don't fit happ bases, the shaft is the wrong diameter.
