Author Topic: Twist and turn joystick?  (Read 922 times)
locash
  • Last login:March 22, 2008, 06:45:21 pm
  • Got cash?
"I believe that every individual is naturally entitled to do as he pleases with himself and the fruits of his labor, so far as it in no way interferes with any other men's rights."
Abraham Lincoln
Chemixtry
  • Last login:January 22, 2021, 07:58:17 pm
  • If an experiment works, something has gone wrong
Re:Twist and turn joystick?
« Reply #1 on: November 10, 2004, 05:37:34 pm »
I think it is just a rotary joystick
Experience is directly proportional to equipment ruined
NoOne=NBA=
« Reply #2 on: November 10, 2004, 06:50:02 pm »
It's not a true rotary.
It's a Xybots stick.
The true rotary sticks will spin in a circle, much like a spinner.
Xybots used a twist stick on the dedicated machines that let you turn 90 degrees left or right by twisting the stick far enough to hit the switches on the add-on card.
It will only go far enough to hit those switches.
That gives you a 3-axis digital stick.
« Reply #3 on: November 10, 2004, 09:03:58 pm »
I thought I read that they also return to the center (the twisting I mean) using a spring.  Is that correct or does it just use the leafs on the switches to ping it back?
NoOne=NBA=
« Reply #4 on: November 10, 2004, 09:05:11 pm »
I'm not sure WHAT makes them return to center, but they do.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #5 on: November 11, 2004, 11:42:30 pm »
Yeah, there's a spring.  You just can't see it, 'cause it's internal.
usedelectronics
  • Last login:January 06, 2019, 02:57:37 am
« Reply #6 on: November 12, 2004, 03:45:18 am »
Correct. A single spring, located on the back side of the left/right turn switch plate returns the handle to center.
usedelectronics
« Reply #7 on: November 12, 2004, 03:55:17 am »
« Reply #8 on: November 12, 2004, 07:59:21 am »
Thanks for the pic - that explains it well...might have to have a think about trying to make one of these...
Kremmit
  • - AHOTW -
« Reply #9 on: November 12, 2004, 11:35:44 pm »
Oops. Not internal- my bad.  That's what I get for posting without actually going and taking a look.  :-[
« Last Edit: November 12, 2004, 11:57:44 pm by Kremmit »
