May 07, 2024, 06:54:11 pm
Which of these designs do you think is "better" for a mame cocktail cabinet and why? I'm going to base it off of Kyle Lidstrom's plans but I'm not sure which ones to use. The main difference is that the Pac-Man cocktail has a base and the Ms. Pac-Man does not. Any thoughts? Thanks!
sounds good,suggestion, if buying the art where it is already cut out, like from twobits.com, don't cut out the top until you have the art in hand, then just use the art as a template for the top.
