Main > Monitor/Video Forum |
ArcadeVGA card and Direct 3D |
<< < (2/3) > >> |
Scanner:
I do have the older AVGA 7200 and I installed drivers I got dowloaded from this forum somewhere. I had problems with the drivers provided on the CD. I will check the exact driver version when I get home. If we ruled out Direct X 9.0 then I suspect it might be a resolution setting because I can run the emulators in a normal window but get the error when I switch to full screen. :-[ ArcadeVGA 7200 WinXP DirectX 9.0 |
Troz:
--- Quote from: Space Fractal / Denmark on January 19, 2005, 02:28:26 am ---ArcadeVGA (old version, wich I have) 7200 does NOT support 320x240, but 321x240. This can cause some problems in some emulators. --- End quote --- :-[ Well don't I feel very silly now... I completely forgot that the ArcadeVGA card didn't support 320x240. I made a custom resolution of 321x240 in FCEU and bingo - it went full screen. Thanks! |
Scanner:
Yup that did the trick! FCEU now works. I think VirtuaNes is better though and I would like to get that running but it doesn't have a custom res setting. |
Troz:
Argh, all is not well for me afterall. I needed to setup a 180 degree monitor rotation for my cocktail cabinet in the ATI Control Panel. Once I did that I started getting the same "DirectDraw: Error Setting Display Mode" error, regardless of the resolution. Any thoughts? |
Troz:
Still no luck no matter what I do. Can someone else with an ArcadeVGA and FCE Ultra try this? Rotate your screen 180 in the ATI Control Panel and try running FECU in fullscreen mode. Thanks. |
Navigation |
Message Index |
Next page |
Previous page |
