Main > Main Forum
SlikStik *New Product Sneak Peek*
Pages: << < (2/6) > >>
SpamMe:
How long will the finish last in a high-use environment?
grueinthebox:
Those are hot - much better looking than the plain stainless, IMO.
How tall (long) is the conbined shaft and ball top on these things?  I notice your old sticks say they're 1/4" LONGER than the original Happ part...  Any chance of getting something maybe a bit shorter?  I'd personally like something about 1/4-1/2" shorter than the standard Happ stick...
Need anodized aluminum pushbuttons to match...  O.o
Bgnome:
--- Quote from: SirPoonga on November 04, 2004, 11:05:54 pm ---We were talking in chat.  Now come up with a clear one we can light up :)
is it just me, or does that shaft look like it might have a hollow area through the center?  if you stick an acrylic sphere on there with a LED, you might have some pimpin sticks.. ;)
paigeoliver:
If you want shorter handles then just install a piece of wood between your joystick base and control panel as a spacer. I have seen this done on several conversion games I have owned.
Gunstar Hero:
--- Quote ---How long will the finish last in a high-use environment?
Well, I'm sure they're meant more for home use.
Go to full version
