Author Topic: *Fresh problem* Dualshock2 modification  (Read 1344 times)
Marcos
  • Last login:November 03, 2004, 08:39:58 pm
« on: November 03, 2004, 06:55:25 pm »
Hi, im a new user, im really just searching for an answer/solution to a rather frustrating problem. This may belong in the controls sub forum.
Basically, I need to somehow make my PS2 think that the D-pad and left Analog stick have swapped around. Simple as that, but i've no idea if this is impossible etc.
Input would be helpful as you guys seem to know much on this subject :)
« Last Edit: November 03, 2004, 07:33:30 pm by Marcos »
Marcos
Re:*Fresh problem* Dualshock2 modification
« Reply #1 on: November 03, 2004, 07:24:03 pm »
Well, i've taken one step:
I can see the pins, seems like a weak way to connect but has worked for years. Now i dont really know what to look for or how to test it
« Reply #2 on: November 03, 2004, 07:26:42 pm »
Hrmm...  I'm not sure if that would be possible.  I don't think it can be done, but I may be wrong.   ???
Marcos
« Reply #3 on: November 03, 2004, 07:36:24 pm »
Im guessing the analog signal and dpad signal are completely different?
I mean, i probably wouldnt mind losing the left analog at all, may become a problem in the game though.
Im thinking ahead, if this fails, i may have to pay someone to program an adapter that does the job. No idea how much this would cost but it would simply have to translate the d-pad directions and pressure sensitivity levels (very important) to the analog stick signals
« Reply #4 on: November 03, 2004, 07:58:22 pm »
What are you trying to accomplish?  (What game?)
Marcos
« Reply #5 on: November 03, 2004, 08:42:46 pm »
GTA: San Andreas. R* decided to not give players the choice of driving/controlling with the D-pad, instead you are forced to use the analog stick. Unfortunately i've spent the past 3 years putting heavy  hours on the other 2 GTAs but playing with the D-pad. So its really frustrating to use the analog stick now, to the point where i'd rather just not play the game.
But if i can find a solution for it i dont mind paying for it. But it would have to be good pressure sensitive d-pad like the GTA3 and VC.
