Author Topic: Hacking/modding HotRod controller?  (Read 2179 times)
quarterback
  • Last login:August 16, 2023, 10:51:41 pm
« on: October 30, 2004, 10:14:53 am »
I first started MAMEing on my home PC years and years ago, but never had the money and personal stability to put together a dedicated Cabinet.
So now that I've got a house, I've decided that a full sized- cabinet is in my near future.  I'm still torn on where I'll end up, however.  I really don't have the time/skill/tools/space to build a cab, but I can't see paying $1000 for one of these kits that places sell.
SO, until I can find a cabinet in my local area to purchase/pick up, I'm thinking about just buying the HotRod control panel.  It's "only" $100 and will at LEAST get me out of the completely inadequate world of keyboard-only-controls.
My question is this.  How much of the HotRod could I then re-use when I put together my full cab?  I'm ASSuming that I could pull/use all the buttons and joysticks, but what about the keyboard encoder?  Could I add anything to it?  More buttons?  A trackball?  Spinner?  Or would I have to replace it with something else?
-- Chad Tower
Re:Hacking/modding HotRod controller?
« Reply #1 on: October 30, 2004, 10:49:36 am »
You could use everything from the HotRod: buttons, joysticks and encoder.  You can add extra buttons to the encoder, check out my how-to: http://mamewah.mameworld.net/hotrodmod.html
You would need an optical interface for trackball/spinner, eg an Opti-pac or Oscars pre-hacked mouse.
quarterback
« Reply #2 on: October 30, 2004, 11:53:38 am »
Beautiful! Thanks for the info.  That's what I wanted to know.
I've got a couple other questions re: the HotRod.
I realize the joysticks are 8-way so games like PacMan and Donkey Kong won't play as well as they would with a 4-way, but there's a comment on RetroBlast that says they "can be switched from 8-way to 4-way operation by flipping over the actuator in the joystick."
Does doing that really give you 4-way action or are the sticks still not really suited for 4-way games?
And how tough would it be to swtich out one of the sticks with a 4-way?
-- Chad Tower
deadmoney5
  • Last login:February 03, 2020, 11:02:02 pm
  • I don't feel tardy
« Reply #3 on: October 30, 2004, 12:05:07 pm »
Flipping over the actuator to get 4-way doesn't do you any good within Mame..you can still PHYSICALLY move to the diagional, which is what matters in 4-way games...
you might as well just leave it in 8-way mode and get by until you get an actual 4-way dedicated joy or the T-stik plus which switches on the fly
quarterback
« Reply #4 on: October 30, 2004, 12:11:38 pm »
Thanks.  I was looking at the T-stick plus and will probably just grab 2 of them so the dual-joystick-games will have a matched 'feel' on both sticks.
Thanks again.
-- Chad Tower
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: October 30, 2004, 04:51:51 pm »
What deadmoney said . . .
There is also the OmniStik prodigy from www.groovygamegear.com which is 4/8 way switchable from above the panel.
StephenH
« Reply #6 on: November 02, 2004, 12:45:06 pm »
The HotRod controller is good.  You can build a cab, and in fact even mount it into the cab if you wanted to.   Additionally, there is a way to switch the joysticks to 4-way if needed, although I did not find it hard to play pac-man in the 8-way mode!
As for trackballs, spinners, and the like, you need to buy those separately.  There is however, interfaces that can make a trackball act as a mouse input, and a spinner as a mouse axis, game port axis, or USB game control axis.
