Author Topic: What could I use for microswitches instead of soldering  (Read 890 times)
blueoakleyz
  • Last login:November 01, 2004, 09:03:08 pm
  • PS2-Arcade
« on: October 27, 2004, 01:05:56 am »
I'd solder to the PCB of course, but to make less of a mess of things, what could I use to attach a wire to a microswitch connector without soldering to it? Like some kind of metal sleeve of some sort? Where I'd stick the wire in to one end/solder it to the sleeve and then stick it to the microswitch prong
johnnysmitch
  • Last login:November 16, 2006, 02:22:05 pm
  • I want you to MAME me as hard as you can
Re:What could I use for microswitches instead of soldering
« Reply #1 on: October 27, 2004, 01:09:07 am »
You want quick-disconnects (female), most likely .187 size - check out the buy/sell/trade forum.
paigeoliver
  • Awesome face!
« Reply #2 on: October 27, 2004, 01:10:08 am »
Um, you don't have to solder to microswitches at all. Just go down to the autoparts store and get some .187 quick disconnects. They have them with all the electrical stuff because car speakers use that size.
blueoakleyz
  • PS2-Arcade
« Reply #3 on: October 27, 2004, 01:26:39 am »
Here's another question
if I were to make a cheesy coin door for my Ms. Pac-Man cab, like just get the red slots or just paint them red lol and cut a slot for coins, could I probably construct something with the microswitch they use in real coin doors (with the long wire) where the coin falls onto a little shovel-like thing, throws the wire out of balance, pushing it down, activating the microswitch, gravity pushes the coin off and then back goes the wire up to it's normal position?
SirPeale
  • Green Mountain Man
blueoakleyz
  • PS2-Arcade
« Reply #5 on: October 27, 2004, 01:59:47 am »
No shipping cost?
Tiger-Heli
    • Tiger-Heli
« Reply #6 on: October 27, 2004, 08:10:24 am »
If using a I-PAC or KeyWiz, there are screw terminals, so no soldering to the PCB either.
No soldering to the sleeve unless you want to.  (They're crimp-on connectors).
SirPeale
« Reply #7 on: October 27, 2004, 08:30:23 am »
Ken Layton
  • Guru
  • Technician
« Reply #8 on: October 27, 2004, 11:10:25 am »
All modern commercial arcade games use crimp-on quick disconnect female .187 (a.k.a. 3/16") terminals. This is exactly how how build (and repair) control panels is with quick disconnects.
Bob Roberts has a crimping tutorial on his website.
« Reply #9 on: October 27, 2004, 11:17:25 am »
BUY FROM PEALE!!!  :D
You can't beat the price  (6$ shipped for 100!) and he gets em to you quick!  :)
blueoakleyz
  • PS2-Arcade
« Reply #10 on: October 27, 2004, 01:02:24 pm »
"If using a I-PAC or KeyWiz,"
What are these?
Remember I am using a Playstation 2 right now, not PC, if it's a PC-only thing.
Tiger-Heli
    • Tiger-Heli
« Reply #11 on: October 27, 2004, 01:07:51 pm »
What are these?
Ooops, yep, my bad -
I-PAC - www.ultimarc.com
KeyWiz - www.groovygamegear.com
You will want one if you ever make it into a MAME machine.
