Author Topic: Cocktail for first cab.... too hard?  (Read 1275 times)
  • Last login:Yesterday at 04:31:28 pm
« on: October 17, 2004, 01:23:11 am »
I think I want to build a midway-style pac-man cocktail as my first cab (it's the only type my wife will likely go for) but I'm not sure as to how hard it is to build.  I'm pretty confident about my woodworking skills - the thing that troubles me is the mounting of a monitor without its casing and some of the wiring on the inside.  Any thoughts?
Gunstar Hero
  • Last login:September 28, 2014, 01:51:17 am
  • Back in action!
Re:Cocktail for first cab.... too hard?
« Reply #1 on: October 17, 2004, 02:46:49 pm »
No worries! A Midway-style cocktail cab is easy to build, being that it's basically a big box with a couple control panels on the end and a top with a monitor attached to it.
Plus there are some AWESOME plans out there for them, and plenty of room to customize!
My first scratch built will be a Midway cocktail for sure.
missioncontrol
  • MC-Retro says Wot!
  • Trade Count: (+13)
  • Last login:May 23, 2021, 12:53:30 pm
« Reply #2 on: October 17, 2004, 03:12:48 pm »
Kyle Lindstrom has some really detailed plans that may help out, They are very detailed and very usefull.......
they are located at:
http://www.mikesarcade.com/arcade/cabplans.html
good luck
whammoed
  • Last login:Today at 09:05:02 am
  • Crack don't smoke itself
    • NiceMite
« Reply #4 on: October 17, 2004, 11:03:52 pm »
yep, my first two were cocktails...turned out great:
http://web.tampabay.rr.com/whammoed/pactacular/pactacular.htm
http://web.tampabay.rr.com/whammoed/whammocade/whammocade.htm
heh, funny you posted here as it is your whammocade that has inspired me to build my cocktail.  Thanks for the great work!
rjarcade
  • Last login:July 28, 2006, 06:44:48 am
« Reply #5 on: October 18, 2004, 08:11:27 am »
I think the whammocade has inspired quite a few of us!
Dexter
  • Patriotism, the last refuge of the scoundrel. -- Irish, darnit!
  • Last login:February 01, 2024, 04:36:19 pm
  • "MAKE POVERTY HISTORY......."
« Reply #6 on: October 18, 2004, 08:15:52 am »
I've just finished my first cocktail cab for a friend. Mounting the monitor is indeed the hardest part (well for me anyway). I bolted the metal 'ears' on the corner of the tube to metal braces then screwed these to mdf with the shape of the tube cut out. Awkward, but as it's going to a friend I want as solid a mount as possible. I'll post pics when available.
Dexter
Craig
  • Last login:September 29, 2014, 05:51:56 am
    • Creation on the Web
« Reply #7 on: October 18, 2004, 08:25:38 am »
You have some bloody great cabs there! I like the pic with Mortal Kombat on screen.
I love the life I lead. I wish I could afford it.
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« Reply #8 on: October 18, 2004, 09:08:47 am »
actually it was pactacular that first got me thinking about building one
« Reply #9 on: October 18, 2004, 09:31:48 am »
I think I'm going to go for it but I am really nervous about the monitor.  I'm not even sure how to remove it from it's casing (although I'm sure if I actually tried I could do it).  What particularly worries me though is once the monitor is caseless, isn't there a risk of a fire or a short or a power surge or something?  I keep reading that this is very dangerous.
Imagine if after months of convincing my wife to let me build one of these things that it ends up burning the house down...
ericball
  • Last login:January 30, 2024, 03:07:18 pm
« Reply #10 on: October 18, 2004, 02:08:08 pm »
The guys on the Monitor forum can probably answer your concerns better.  The risks (assuming you use some common sense) are minimal.
MAME Projects % completed:
2004 3 sided cocktail cabinet w/ modular CP <25%
2004 Tempest cabinet & CP > 75%
2017 Raspberry Pi Zero W w/ Lakka microconsole 50%
2021 Vertical Bartop - in progress > 80%, 100% functional
Tiger-Heli
    • Tiger-Heli
« Reply #11 on: October 18, 2004, 03:33:56 pm »
Also, if you saw the whammocade -
One of the best things about a cocktail cabinet (other than that the wife is more likely to approve one) is that since you can sit on any side of it, you can use MAME's screen rotation commands and play either vertical or horizontal monitor games full screen without building a rotating monitor or two cabs.  Just make an additional CP on the long face of the cocktail.
whammoed
    • NiceMite
« Reply #12 on: October 18, 2004, 03:44:14 pm »
Yes, that was a big plus for me.  That reminds me, I still have some third panels for sale here:
http://www.arcadecontrols.org/yabbse/index.php?board=2;action=display;threadid=22491
currygoat11
  • Last login:May 04, 2018, 11:10:02 pm
  • She's doing it right now!
« Reply #13 on: October 18, 2004, 03:54:09 pm »
be sure to check out http://www.pharaohweb.com/pacman/pacman.html
I'm building something very similar. The site has info about where to get pre-cutout cabinet kits which is what I did and am currently in the process of assembling the thing.
currygoat
cg
Tilzs
  • Last login:February 16, 2011, 10:41:56 am
  • Neat
    • Cocktail Arcade
« Reply #14 on: October 18, 2004, 03:57:12 pm »
I think the hardest part is mounting the monitor. One thing that I didn't do but if I was going to do it over again I'd probably do is an arcade monitor. An arcade monitor I think is a lot easier to mount in a cocktail than a computer monitor because it's designed to be mounted without a case. This way you don't need to worry about what happens when you remove the case.
I didn't use an arcade monitor in my cocktail because I thought the price of one new was too high compared to a computer monitor I had laying around. I do know now however that if one is patient enough you can pick up a decent used arcade monitor for a very reasonable price.
LeedsFan
  • Last login:January 17, 2021, 06:14:23 am
« Reply #15 on: October 18, 2004, 04:23:07 pm »
If I were you I'd go with what you actually want. Never mind mounting the monitor........  do what you want and worry about mounting the wife later!  ;)
