Main > Main Forum
Ergonomic Arcade Buttons Layout - Enclosed Picture
Pages: << < (2/2)
Pacific Ripper:
Thanks for the input. the reason for the  button setup is for the X Arcade Encoder that I am going to use. I will adjust the placement of the joysticks and buttons and I'll post a revised image on this thread.
skid_68:
Look at it like this. How often are you going to use ALL your fingers pressing buttons at once? Never, You only some of the time hit two buttons at once. Most of the time you will only be pressing one button with one finger, jumping around the button layout. Think about it.
Pacific Ripper:
Well, some fighting games will have you press up to four buttons at a time. Since I am into that genre, I want a design that provides ease in doing that. Maybe I'll just use the X Arcade's layout.
DrewKaree:
--- Quote from: pacificripper on October 16, 2004, 03:36:10 pm ---the reason for the  button setup is for the X Arcade Encoder that I am going to use
why would the encoder you're going to use have anything to do with dictating where your buttons are placed?  You should be able to put them on the backside of your machine, if you so wish, and the encoder just tells your computer "When I press this button - which I don't care where it is - I'm supposed to send this certain signal.
It's the top row of buttons that prolly everyone is commenting on.  If that's your "home row", you've gotta have some wicked long fingers, or you are super precise about finger RE placement after moving them from a button.
--- Quote from: skid_68 on October 16, 2004, 03:40:53 pm ---Look at it like this. How often are you going to use ALL your fingers pressing buttons at once? Never, You only some of the time hit two buttons at once. Most of the time you will only be pressing one button with one finger, jumping around the button layout. Think about it.
Right.  Think about it.  Although you are prolly trying to tell him it's ok, you are reinforcing my point, and others.  If the buttons are spaced as far apart as they are, it WILL be harder to reposition your fingers, as well as making it MUCH more difficult in performing certain combos in btmups or other such "combo move" button pressing games.
And the layout seems as Jakobud says.  Either you've got to stand at an angle, or move your elbow so far out like a chicken wing as to become uncomfortable after only a few minutes of play.  That "splaying" of the buttons prolly wouldn't be as uncomfortable if it were more formed like the guy's mouth in my assessment of the layout  :(  Ouchie.
Pacific Ripper:
Well, As far as the X arcade encoder, it is not programmable when used with a console such as the X Box. This would not be such a big deal if I could reprogram the encoder, but that function is only for the PC. So... I did want a better layout than what X Arcade had for their control panel, and through trial and error, I'll eventually get there, I hope. Thank you all for your input into this. All the criticisms help. Anyways, here's a revised version of what I had before.
Pages: << < (2/2)
Go to full version
