Main > Main Forum
Finishing Touches: The Power Switch
Pages: << < (3/4) > >>
Jack:
COBeav,
Can you go into detail on how to wire the 12v relay?
Scott did something similar with his unicade, but he did
not go into detail.  I am very interested in hearing how you accomplished this.
COBeav:
--- Quote ---COBeav,
not go into detail.
yo:
man >:(
you guys make things so tough...just use reguler push buttons with microswitch...
spice up all the wire to atx power supply..and strip the wire that goes to front of your computer..then spice those 2 wire on normal open and ground...then press 1 arcade button and you cabinet turns on...easy aint it..hope i am helping..good luck
ErikRuud:
Hey Yo,
Splice, not Spice.
Your idea works, if the PC power supplie already works from a "Momentary" pushbutton.  Mine does not, it physically clicks on and off.
Jack:
COBeav,
That would be great!  I have been looking for instructions on wiring a relay for quite a while.
Go to full version
